Pulling motor tips/tricks
Old Sep 15, 2004 | 07:59 AM
MustangGT221's Avatar
MustangGT221
Do I have to pull the tranny with the engine, or can I just unbolt it from the tranny and unbolt the motor mounts and pull it out?
Old Sep 15, 2004 | 10:55 AM
EPNCSU2006's Avatar
EPNCSU2006
You can leave the tranny, but you must support the front of it.
Old Sep 15, 2004 | 03:58 PM
evilbeast's Avatar
evilbeast
i have a question as well, if anyone has a chance input, i have a 351 in my truck, and it just died, it finally exploded, and the new one is gettin ready to go in, is it easier to unbolt the torque converter while it is in the transmission, or should i just pull the converter out with the motor, or is that even possible. i havent pulled this motor out in so long that i dont remember, i didnt mean to clutter up ya thread mustang, but it goes along the same line!
Old Sep 18, 2004 | 09:09 PM
MustangGT221
Ok I have the engine all disconnected, on a lift, and ready to come out. I unbolted the engine from the transmission, and am trying to pry the engine off the tranny. I shook annd pulled that motor all over the place, up down, jack on tranny pushing slightly up/down...i wrestled with it for over an hour and it barely moved. It's still only off the tranny by a 1/2-1". What the heck is wrong with this and why won't it separate...I didnt want to have to pull the tranny w/ the motor as it seems a more difficult task being it has a transfercase on the end. Clearance wise i can just pick up the motor but it just wont separate off the tranny....any ideas or suggestions?
Old Sep 18, 2004 | 09:17 PM
Randyb12's Avatar
Randyb12
Did you take off the inspection plate? the sheet metal cover at the bottom of the trans.
Did you unbolt the torque converter, it has 4 bolts.Did you remove the stater? Check for more bell housing bolts.
Old Sep 18, 2004 | 09:19 PM
MustangGT221
It's a 5 speed mazda trans so no torque converter. I didn't take the sheetmetal cover off though...
Old Sep 18, 2004 | 09:36 PM
c_rossman's Avatar
c_rossman
Yes, it should just slide right off, Sometimes it helps to jack the tranny up as high as it can go, I am sure it is binding on the input shaft because the engine and tranny are at slightly different angles. Just take your time, specially if you need to reuse the clutch because the fingers can get bent very easy.
Old Sep 19, 2004 | 02:58 PM
MustangGT221
So do I need to take that metal cover off? How do I do that it seems like it won't easily come off. I just wrestled with it for another hour and something aint right here. Its all unbolted, you can see a gap around the top 1/2 of the transmission/engine... but if you look at where the rear seal is...there is barely a gap at all...
I can grab the motor and try turning it and it will rotate a little but i've pried on that thing as much as i can and it won't come off. Right now I took the lift off the engine so I could put it in the garage (so it doesn't rain on the lift) and the engine is back on the motor mount. There is still a gap at the top of the tranny, this is really ticking me off and I don't know what to do...
Old Sep 19, 2004 | 05:12 PM
Randyb12's Avatar
Randyb12
At this point it might be easier to pull the trans too.`
Old Sep 19, 2004 | 05:18 PM
fordman300's Avatar
fordman300
did you pull the driveshafts so youi could slide the tranny back? how about the shifter? if you have then make sure the studs on the tranny mount are out of the crossmember. one more thing the inspection cover stays on the motor side because it is behind the flywheel . if you have done all of the above then they should slide apart
Old Sep 19, 2004 | 05:22 PM
MustangGT221
I didn't unbolt the tranny, the shifter, or driveshafts. I intended for that all to stay because I was told I could leave the tranny where it is. The tranny still moves around a lot in the rubber mount when I shake the engine. I don't understand why the engine just won't come off the transmission...I didn't think I had to take all this other crap apart.
Old Sep 19, 2004 | 06:26 PM
Randyb12's Avatar
Randyb12
You don't usually. But you seem to be having a problem here. One more time : unbolt the inspection plate from the trans at the bottom half of the bell housing. that is about the only thing that is left to hang it up.
Old Sep 19, 2004 | 07:07 PM
  #28
jcarter's Avatar
jcarter
Jack the transmission up so that the angle of the bellhousing matches the engine and wiggle it back and forth until it releases the transmission. if the transmission will not go high enough then remove the engine mounts so that it will drop low enough to clear any obstruction.
Old Sep 19, 2004 | 08:51 PM
  #29
EPNCSU2006's Avatar
EPNCSU2006
Justin, I think it's just binding up at this point. The transmission input shaft slides out of the clutch disk, and if you have it 1/2 inch apart already, all the bolts should be free and clear. Work on alignment vertically; make sure the engine and transmission are on the same plane front to rear, otherwise the bind will keep them together. Do you have an engine leveler on the hoist? If not, maybe try to hook the chain up so that it holds the engine at a slightly different angle, and also try jacking up the front of the transmission.
Old Sep 20, 2004 | 05:05 AM
  #30
MustangGT221
I do have it on a leveler hoist...it's 1/2-1" apart at the top of the bellhousing but where the crankshaft is, hasn't separated much. I've already unbolted that inspection plate but...does it just slide out?
