Power Window Woes
Only way I could see removing my pwr window motor was to drill out 4 pop rivits that held the arms and crank that raise and lower the window. The motor is fastened to that with three 5/16 bolts before it is rivited into the door.
Here's hoping yours isn't the same.
"I pulled the motor on my 94 Aerostar. I had to drill three holes. There are some small dimples in the metal. Just drill them out. Then you can take a socket set and remove three bolts. The motor comes right out."
So maybee that's a better way. Now, as I said before the three bolts are a 5/16" socket (8mm is the same). You will need to drill your holes large enough to fit the socket in.
I'm gona take a closer look at my van tomorrow and see if those dimples are there. The one I removed the motor from was my parts van so I didn't mind drilling out the rivits for the track.
It's great to have someone to chat with about this. Do let me know if you see these target "dimples" on the panel. I noted the rivets and was afraid of having to drill those out and then coming up with a new fastener for the mechanism. The toothed gear of the mechanism is steel and the teeth seem to be in fine shape. I assume the teeth on the motor gear are shot since when I push the toothed mechanism towards the inner door panel it grabs and runs pretty smoothly. The motor otherwise runs strong. I hope when I get it out that I can simply replace that blown cog.
I put it all back together with new fasteners for now since it's about to turn rainy here soon and my wife (the primary operator), prefers to have the car buttoned up, so this'll have to wait until a get another free day.
I used bolts and teflon locking nuts just in case I had to remove it again.
I got a 3/8" hole saw from a snap-on dealer that is used to cut tack welds to make access holes to the bolts inside. Made it nice, clean and fast.
By drilling the dimples out to access the bolts the window track will stay in position holding the window up ( incase of a rainy day before the job is done
).Yes the gear on the motors are plastic. He was refering to the "steel teeth" of the window track.
