Gauge Hook Up Help
Old Nov 5, 2006 | 08:47 PM
06PSD&79460's Avatar
06PSD&79460
Gauge Hook Up Help
hi i just ordered the quad A-pillar and 4 autometer gauges. Pyro, Boost, Trans Temp and Oil Pressure. Trans temp and Pyro i understand what to do. But for the boost and oil pressure i do not know where to hook them in at. i have installed a mechanical oil pressure gauge on my 79 F250 and it was on top of the manifold. but this is an electric on my 06 PSD F350. Any help would be greatly appreciated as i am trying to get ready and install them tom. thanks
Old Nov 6, 2006 | 06:51 AM
raptor131's Avatar
raptor131
for boost i tapped intake elbow. 4 bolts hold it to intake manifold and the plastic tube clamp is one clamp, drill and tap place adpter reinstall, literally took me 15min to install the engine compartment parts. i dunno about oil
Old Nov 6, 2006 | 10:43 AM
Lonewolftx's Avatar
Lonewolftx
Arrow My setup. . . .
I put my Boost probe by the turbo on the inter cooler pipe. Would have put it on the Accufab intake (polished in back ground) as it has a mounting hole but did that mod after I had already done the Boost guage setup.
The Pyro probe at the head of the exhaust pipe, 4" mod.
Don't have a oil temp but you have to mount it in the oil pan and drill a hole for the sending unit. Have to weld it in which is PITA.
Old Nov 6, 2006 | 02:17 PM
chixdigit's Avatar
chixdigit
I did a very detailed post about my pyro and boost gauge install a few months ago..
Do a search in this forum for "gauge install" and that should bring up some good detail for you.
Old Nov 6, 2006 | 07:41 PM
06PSD&79460
thanks guys. i appreciate the help. didnt get to install yet because i got off work late but plan to tom. Which location is more accurate or is it 6 one way half-a-dozen the other?
Old Nov 6, 2006 | 07:52 PM
06PSD&79460
P.S. its oil pressure so it has a sending unit? i didnt want to mess with welding on the oil pan with oil temp.
Old Nov 6, 2006 | 09:52 PM
blackhat620's Avatar
blackhat620
More accurate for which gauage?
Old Nov 8, 2006 | 07:11 PM
concordpete's Avatar
concordpete
Looking for some gauge info also. Went on line to Dieselmanor, they have Isspro gauge kits & they have 2 options for hooking up the pyrometer thermocouple. A clamp & the drill & tap the Exhaust manifold method. The drill & tap is the way to go right? Also anyone tried their $25 can of spray paint (for plastic) to paint the A pillar? Kind of pricey!!!
Old Nov 8, 2006 | 09:19 PM
raptor131's Avatar
raptor131
I chose my location due to the fact that the closest to the intake manifold is what i wanted to monitor as far as boost pressure.but when dealing with pressure, a leak or loss of pressure should be noticed across the board of testing points. but my knowledge of physics is strictly self learned, i believe his is before the intercooler. also the location i used to me seemed like a quick install
Old Nov 8, 2006 | 09:43 PM
Kep4's Avatar
Kep4
Jäger
I saved it cuz you did a great write up, IMHO: www.ford-trucks.com/forums/494902-update-tips-from-autometer-gauge-install-this-weekend.html
Old Nov 8, 2006 | 11:00 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Order an alumnium oil filter cap from Oilguard, they already come drilled and tapped for 1/8NPT. Put a quick disconnect on the cap and on the line to make oil changes simpler, and run it straight from there.
Any other location will require drilling and tapping into either the engine block or oil cooler- neither of which is preferable with the engine still in the truck.
Old Nov 9, 2006 | 07:45 AM
Lonewolftx's Avatar
Lonewolftx
Wink Painted mine . . .
I took my A piller pod to a local body shop for a paint match to my King Ranch interior. Came out great and not even $25.
As far as where to mount the Boost probe mine is ahead of the inner cooler but as mention, it is a preasure thing and this was a good place to put it prior to the Accufab elbow addition.
I would have put it there had I have had it when installing the Boost probe given it has a hole pretapped. I didn't like the way the line got in the way of the fuel filter and the coolant overflow line (as seen in the pic w/ that location installed). It might be a little more work but it is out of the way of work areas like when you chjange oil & fuel filter.
With an oil line as well that will be one more line running in the same area too.
Options . . .
86f250XLT-4x4
51
Oct 27, 2011 10:57 AM
exiled
Feb 16, 2007 06:39 PM
sailmfast
Nov 2, 2005 11:16 PM
mejer1
Sep 5, 2004 05:37 PM
beretzs
Nov 13, 2003 09:38 PM
