Oil pump Ticking
Old Sep 5, 2004 | 12:07 AM
Mr.JP's Avatar
Mr.JP
Oil pump Ticking
I just installed a new oil pump, the old one was fine but i needed to replace the oil pan gasket, so i did both. But now when i first start the motor I get a ticking for a few seconds. I notice that it goes away after my oil pressure gauge goes up. If i shut the motor off and restart it, It doesnt happen again. Only if I let it sit for about a half hour or more. Both screws were tourqed down to spects. Any ideas? Oil pressure is good no problems there. 95 inline six.
Old Sep 6, 2004 | 01:45 AM
351M's Avatar
351M
that is probly just the lifters rattling a bit till they get oil pressure thats all, no big worry.
Old Sep 6, 2004 | 08:17 AM
FordF150Fixer's Avatar
FordF150Fixer
Some oil filters have anti-drainback valves that leak. The leaky valve allows the oil to slowly drain back from the engine to the pan. When you start the engine after it has been setting awhile, it takes a little time to re-fill the filter and get oil up to the lifters.
There is an older thread on this site that addresses the problem. I had the same problem that was fixed by replacing a Fram filter with a MotorCraft filter. If thats your problem, its a cheap fix. Good Luck.
Old Sep 9, 2004 | 11:03 PM
Mr.JP's Avatar
Mr.JP
I got to thinking, could it be where the pick up tube and the oil pump meet is leaking, all the oil is draining out of the pump and taking a few seconds to fill back up. I started thinking about it and there wasnt a gasket to put between the two.
Old Sep 13, 2004 | 02:51 PM
gatesj's Avatar
gatesj
I didn't touch the oil filter or pickup tube when I did the pan on my 300 but I had to just now on my 351w. I would assume they're the same basic idea. There was no gasket between the pump and the block (pressure side) but there was definitely one between the pump and the tube (vacuum side). I made sure to clean the surfaces up perfectly and use a new gasket WITH NO SILICONE!!! From what I understand, if a piece of silicone gets into the oil pump it will lock the pump up and goodbye pump drive shaft, oil pressure and engine. That stuff is tough when it cures and will not displace, and the oil pump tolerances are very close. That's another reason to use a quality one piece oil pan gasket and no silicone there either. With the pump screen you have a chance of that catching chunks of silicone before it gets in the pump but even if it does you don't want crap caught in the screen.
rustyrudder
Mar 12, 2015 10:03 PM
dencrawford
Bronco II
Mar 19, 2012 03:03 PM
dawgbigsam
1983 - 2012 Ranger & B-Series
Aug 3, 2010 08:05 PM
zjmj17
1997 - 2003 F150
Feb 14, 2007 06:48 PM
rabbitt71
Bronco II
Apr 4, 2006 01:58 PM
