Tick Tick Tick Tick
Old Mar 3, 2015 | 07:15 AM
rustyrudder's Avatar
rustyrudder
Tick Tick Tick Tick
Howdy folks,
So I've just finished rebuilding my 88 300, and it runs great, stellar oil pressure, great compression, all that jazz.
But it has a tick. I'm almost positive it is not an exhaust leak, but rather valve train, and I'm not sure what would cause this. When I rebuilt the motor, I had a valve job done, so valves are all reground and should be fine. However I did not replace the rockers or pushrods and I was wondering if something here could cause the tick? Oh, lifters are also brand new.
It's not so much the tick that bothers me; it's not knowing what is ticking that drives me nuts. Any help is greatly appreciated!
Old Mar 3, 2015 | 10:01 AM
The Frenchtown Flyer's Avatar
Did you have the valve guides replaced?
Probably worn guides if not.
Any time a valve job is done the valve guides should be serviced first. Kinda like leveling a surveyor's transit before making elevation measurements.
Old Mar 4, 2015 | 03:21 PM
rustyrudder
Hmmm, I'll have to dig out the work form, but what the machinist advised was that when he did the valves, he would check for worn valve guides and only service the one's that needed it. When I was watching the dollar signs fly by this seemed like a good idea. I'm a little ashamed to say I don't know which ones he did if any, and I never checked when I assembled the motor. Is there a way I can check for worn valve guides without pulling the head??
As a side note, The motor I rebuilt was a donor with 116xxx ish miles on it, and I had never heard it run before hand.
Old Mar 12, 2015 | 10:03 PM
rustyrudder
An update:
Valve guides are all good.
Also, I checked up on what's going on underneath the valve cover and found that the rocker arms were worn. Replaced those then noticed that one of the lifters wasn't filling the rocker arm, popped a new lifter in and problem solved.
But I had a heck of a clatter goin on. Worse than when I started with just a little tick. I try to follow the old doctor's adage of "first do no harm" or something like that, so I'm feelin pretty low.
Anyways, did some more digging and discovered that pushrod number one is bent. The only time I've ever seen a bent pushrod is on a boat when the exhaust manifolds leak water back down into the head. So I'm at a loss; what would cause a bent pushrod? The only thing I can think of is that I had the head shaved .015" and I'm using stock length pushrods...maybe? A friend of mine tried to show me that the rocker bolt took too many turns past zero lash to tighten, but I was under the impression that with an efi head you just torque the rockers down and go.
Anyways, thanks for readin through that, I appreciate all the help!
Brigart
Jan 8, 2010 07:55 AM
natron037
1997 - 2003 F150
Mar 17, 2006 08:41 AM
highrider76
19
Apr 30, 2005 05:25 PM
72earl302
Nov 5, 2004 02:28 PM
djmac
Oct 16, 2004 01:56 AM
