2.9 v6 oil pressure problems
Old Aug 1, 2010 | 11:34 AM
dawgbigsam's Avatar
dawgbigsam
Question 2.9 v6 oil pressure problems
the top end started ticking after highway runs.drove around town 4 a few and ticking quit.only after highway runs would it tick.after a while no oil pressure below 2000 rpm's.put new oil pump and screen on and did not fix still no pressure at idle.and when run as it warms up takes more rpm's for pressure to come up!
Old Aug 1, 2010 | 12:57 PM
michigan66's Avatar
michigan66
Tell us more about your truck, such as: year, number of miles, when major (30K or 60K miles) service was done.
Is this something that has just appeared or has it been building up for a while.
Old Aug 1, 2010 | 01:22 PM
dawgbigsam's Avatar
dawgbigsam
its a 1992 approx. 198000 miles.the problem has been building for a little while no major service just regulor oil changes and tune ups
Old Aug 1, 2010 | 06:19 PM
michigan66's Avatar
michigan66
When you changed the oil pump and screen, what was the condition of the pump, screen and oil pan? Were they fairly clean or was there a lot of gooey gunk over everything? If goo and gunk were present in abundance, you may have some lines plugged up that restrict the flow of oil though the engine.
Have you taken off one of the valve covers? What was its condition and the condition of the top of the head?
When you say there was no oil pressure after highway runs, do you have a direct reading gauge or are you relying on the Ranger's pressure/no pressure gauge (basically an on/off switch)?
Old Aug 3, 2010 | 08:05 PM
V8Ranger302's Avatar
V8Ranger302
The 2.9L where known for that problem. Most of the time it was because of a rear main bearing. The bearing can spin out of place and block the oil hole. Some where also know for the oil return holes to plug up, especially considering the miles you have on it
frikosz
2009 - 2014 F150
16
Oct 26, 2023 07:19 PM
2010F350
6.4L Power Stroke Diesel
Nov 13, 2015 11:52 AM
IDIDieselJohn
39
Dec 30, 2013 08:14 PM
Woodlums
1997 - 2003 F150
Jan 12, 2012 07:30 AM
dasears
May 24, 2011 01:17 PM
