auto-hubs. how long will they last?
i have a 11 year old ranger with 75,000 miles and i was wondering how long i can expect the auto-locking hubs to last. i have the push-button 4wd and stock 235/15 tires, though i run 215/15 tires in the winter when 4wd is used the most. i just replaced my front axle u-joints so i guess my next "weak link" would be the hubs.
with stock tires and little 4x4 use the hubs go pretty quick. if you use them often (once a month at least) then you are keeping them greased and they should last a lil longer. but most of us running 37" or so tall tire or bigger they start to wear out pretty quick. uss them enough to make'em feel wanted but don't abuse them and they could possibly outlast the truck. the hubs on my 93 f150 went out at about 105K miles running 31-33" tires doing very mild mud playin
-cutts-
-cutts-
i've seen a set with almost 300 K on the body with one rebuild at about 200k, another set i've seen went at about 15K, depends on how you treat them.
The 200K ones were on an '85 suburban running 32 A/T's that had 4x used at least once a month. (the early GM ones were known for having the same issues as ford ones, esp. since they're both made by warn) The 15K's the guy had never used (ever), went to engage 4x for the first time, one hooked up, and the otehr started clicking immediately.
With average use and medium tired i'd figure about 80K would be reasonable.
Justin
Justin
I found (with 35's) that from the second you submerged them, you had about 48 hours of reliable enguaging, then about 2 weeks of "yeah it might work, it just might take 5 minutes to get them to enguage." Then you had 2 wheel drive. The piece that wears out on (at lest mine) is a PLASTIC washer or something like that. I suppose that teh sand and dirt in the water wore it down rapidly. I also trashed my bearings by not repacking them with grease after submersion in about 6 monthes of twice a month driving. sand is erosive
tesserra
04-02-2008 09:54 PM
