Crossbows for dummies
Old Sep 3, 2004 | 05:29 PM
thomasr's Avatar
thomasr
I’d like to get into bow hunting again, but thought I’d check into crossbows. They’re now legal to use here in GA, not to mention my bad shoulder probably won’t hold up to a lot of compound bow practice. I don’t want to spend a fortune, so what’s a decent brand/model? What’s a reasonable FPS? I see they can get up to as much as 350 FPS or better, but is all that really necessary? Would a 250 or 270 do the job? What are some features to look for? Scope? Sights? Parallel or cross-quiver? I’m hearing there are a couple different kinds of trigger/release mechanisms…what are the advantages? I’m only slightly more knowledgeable about compound bows but even that knowledge is about 10 years out of date...so basically I’m starting all over again. The guys I hunt with are real “gear-hounds” and won’t hunt with anything less than state of the art stuff…shoot, I thought it was called primitive weapons for a reason. Anyway, I appreciate your wisdom and advice.
REX
Old Sep 3, 2004 | 08:41 PM
thomasr's Avatar
thomasr
Wow...I guess I found something on FTE that nobody either knows anything about or has an opinion about. That's gotta be a first!
Old Sep 4, 2004 | 01:21 PM
thomasr's Avatar
thomasr
Wow...it really does appear that nobody on FTE knows anything about crossbows. I'm in utter amazement
Old Sep 4, 2004 | 01:30 PM
Mike W's Avatar
Mike W
I read a test on them one time, also stayed in a motel 6. , but I digress. As I recall, there is such a drop in the arrow that you really need to know the exact range of the target. Also think the arrow is called a bolt, why I don't know. It does not have threads on it.
Old Sep 4, 2004 | 01:41 PM
thomasr's Avatar
thomasr
Ha Ha ...thanks Mike. Sounds like you may actually know about as much about crossbows as I do. Besides the FPS thing, I've noticed that the bolts can vary by length...from 15" up to 22". Actually in the 22" range they go back to calling them arrows. Is one size better than the other for hunting? There's also the ft lbs. in energy factor...faster arrow/bolt speed doesn't always seem to equate to more down range energy. The manufacturers also seem to make a big deal about power stroke (no, not the diesel ). And greater draw weight doesn't allways equate to greater speed or down range energy. Let's not even get into the particulars of the arrows/bolts yet...that seems to be a whole other (although related) science. Thanks for the try Mike...I was beginging to wonder if I had been black-listed somehow.
REX
Old Sep 4, 2004 | 01:51 PM
Mike W's Avatar
Mike W
I just happened to notice your location. I spent a couple of years in Wahewa, while in the Navy. Gas off base was $.75.
Old Sep 4, 2004 | 01:58 PM
thomasr's Avatar
thomasr
Mike,
Actually I need to get that changed. I moved away from there about a year ago. I'm in the AF and got reassigned to GA. Actually I should say "back" to GA...I was stationed here before HI...had the opportunity to come back...didn't think about it twice. HI was nice but it's a lot nicer for me being back in the good ole south.
REX
Old Sep 4, 2004 | 02:07 PM
Mike W's Avatar
Mike W
I went from there to Korea, liked it better. Thanks for defending our country.
Old Sep 4, 2004 | 02:12 PM
thomasr's Avatar
thomasr
It's been an honor and a privelage to serve...thank you for the thanks...now if somebody only knew something about crossbows...........
Old Sep 4, 2004 | 04:59 PM
tex71's Avatar
tex71
Try www.hunting.net and go to the bowhunting forum on the message board, there are alot of good guys there who I'm sure can help you out.
Old Apr 5, 2008 | 02:27 PM
OzzieO's Avatar
OzzieO
crossbows?
Ive been hunting for years with one. If you're not going for grizzlies....150lb draw weight will do. Its good for deer bear and moose. Horton makes good quality bows and a little cheaper than most.I use a Horton Legend 175lb. Never had a minutes problem with it.
Old Apr 5, 2008 | 09:32 PM
cjben's Avatar
cjben
I think by the time you answered the OP, he has been hunting for years with one also!! good mining!!
Old Apr 6, 2008 | 12:13 AM
blue beast's Avatar
blue beast
Since you have a bad shoulder just use this and it is way more accurte then a bow
or cross bow!! AIRROW RIMFIRE
old farm truck
Nov 25, 2017 07:39 PM
truckfella
Nov 6, 2014 12:20 AM
plumber01
17
Dec 26, 2011 02:15 AM
clux
52
Apr 2, 2011 12:23 AM
ericsmith32
Jun 10, 2006 11:09 PM
