Texas Chapter Join Chapter, Leader: LibTimothy
Looking for a axle.
Old Sep 3, 2004 | 06:02 AM
dbhr's Avatar
dbhr
Looking for a axle.
First time posting hear in the Texas forum glad to see alot of fellow Texans hear. I am looking for a complete dana 44 axle assembly, I am in the Wichita Falls area, any help would be appreciated. Thanks, Billy.
Old Sep 11, 2004 | 10:02 PM
71100's Avatar
71100
Talking
have a whole 79 f 150 pulling 400m out.going 2 put i 6 in sell u the truck$600!! 456 front 456 out back both have rebilt.
Old Sep 12, 2004 | 03:06 AM
79f350ds's Avatar
79f350ds
Do you need a 250 or a 150? I have both.
Doug.
Old Sep 12, 2004 | 03:21 AM
gotdiesel's Avatar
gotdiesel
79f350ds just wonderin on the f-250. do you have the whole front end or just the axle??? what gear ratio??? lookin at replacing the entire front end on a 97 f-250 and would like to get the whole assembley. p.m. or post and let me know. also the 97 is a heavy duty. rated at either 8800 or 8900 lbs. do you think i should go to a one ton front axle instead of just a 3/4 ton??? thanks!!! your help is greatly appretiated
p.s. what part of texas are you in??? maybe we are somewhere close
Old Sep 12, 2004 | 05:47 PM
william_ace's Avatar
william_ace
i am looking for a f150 dana 44 axle and gotdiesel- yes put a dana 60 straight axle under your truck, you will like it
Old Sep 12, 2004 | 10:55 PM
79f350ds's Avatar
79f350ds
the f 250 axles that I have are both dana 44 hd one with 3.54 ratio and one with 4.10 ratio. if you have a diesel you need a dana 60
Doug.
Old Sep 12, 2004 | 11:01 PM
william_ace
where are you located and how much for the f150 dana 44?
Old Sep 12, 2004 | 11:41 PM
gotdiesel's Avatar
gotdiesel
thanks- thats kinda what i was thinking. guess ill keep looking for the dana 60. if yall happen to come across one let me know. im sure ill have to regear it to match the 3.55 rearend in this truck. im sure the 60s will all be 4.10. thanks alot for your input and help!!!
Old Sep 12, 2004 | 11:46 PM
william_ace
re-gear the rear 4.10s are nice to have
Old Sep 13, 2004 | 12:23 AM
gotdiesel's Avatar
gotdiesel
thought about that. the 3.55's pull my 24' gooseneck stocktrailer loaded at 75 mph in overdrive and get about 13 mpg doing it. besides that i can get around 20 unloaded. i would hate to give that up. maybe i could see about adding an overdrive unit that would allow me to run about the same rpms with the 4.10s. that would be really great and give me another gear with lots more towing power. maybe thats something ill look into. what do you think???
Old Sep 13, 2004 | 12:27 AM
79f350ds's Avatar
79f350ds
i,m in leonard tx and the 150 axle came out of a 79 bronco I take 250.00 for it (has 3.50 gears)
Doug
Old Sep 13, 2004 | 09:36 AM
f100guy's Avatar
f100guy
i got either a 44 or a 60 out of my 78 or 79 f100 ranger with a 2.75 gear
relayman53
Aug 17, 2014 07:02 PM
jandlstables
Jan 5, 2011 06:37 PM
gtboy2k
Kansas Chapter
16
Nov 4, 2010 11:39 PM
jandlstables
Aug 16, 2010 09:13 PM
