2001 explorer sport overheating-help
Old Aug 31, 2004 | 09:55 AM
tedebear's Avatar
tedebear
My temp gauge spiked to Hot this morning on the way to work-I immediately shut her down and checked for leaks-none found.I checked coolant in reservoir and it was alittle low but not much-added alittle water.The temp guage went back down but stayed just alittle bit above the normal spot it is usually in and didnt spike back up again-even when running with the air conditioning on. Could this be a thermostat problem? Where do I start?
Old Aug 31, 2004 | 09:59 AM
jonm61's Avatar
jonm61
I would start with the thermostat. That seems to be the most common cause of overheating/running hot that I see in the forums, and it's what mine needed when I had the problem.
Old Aug 31, 2004 | 02:19 PM
LV Dan's Avatar
LV Dan
Definately start with replacing the thermostat as it sounds like it stuck during the first warm up. When you replace the thermostat, I recommend using the Ford Motorcraft part. It is a couple of dollars more but much better construction.
jennkent5454
Nov 14, 2012 08:11 PM
bes7458
Nov 10, 2011 06:23 PM
03SD6L
Mar 2, 2011 11:14 AM
stx4x4
2004 - 2008 F150
Feb 8, 2011 08:10 PM
75Three90
29
May 26, 2010 12:22 AM
