overheat issue
Old Nov 10, 2011 | 03:47 PM
bes7458's Avatar
bes7458
overheat issue
I have had a problem recently with my engine overheating intermitently. The temp gauge spikes up, and sometimes goes right back down, sometimes stays up for a while, but it has never got into the red. Any ideas what could cause this? I also noticed my heater not working from time to time, although it does not seem to coincide with the overheating. Any help on what to check would be appreciated.
Old Nov 10, 2011 | 04:18 PM
wulfman's Avatar
wulfman
Is the coolant resevior low ?
Old Nov 10, 2011 | 04:26 PM
bes7458's Avatar
bes7458
yes, it was low. is that the problem or a symptom? i haven't noticed any white smoke, ect. it hasn't overheated since i filled it up a couple of days ago, but since it is an intermittent problem, i'm not convinced it is fixed.
Old Nov 10, 2011 | 05:44 PM
wulfman's Avatar
wulfman
Are you over filling it needs to be 1/2 inch or so below the min line
Old Nov 10, 2011 | 06:08 PM
bes7458's Avatar
bes7458
I filled it up to the min line. That was the first time I ever had to add coolant. i have ~150k miles. I am wondering why i lost coolant all of a sudden and where it went?
Old Nov 10, 2011 | 06:23 PM
cheezit's Avatar
cheezit
read tsb 09-08-03 then follow it.
jasindude1
1978 - 1996 Big Bronco
Mar 29, 2021 09:46 AM
gsujeff55
Jul 8, 2015 02:32 PM
wildcat421
May 4, 2014 02:57 PM
sd_mountaineer
Jul 20, 2011 11:17 PM
pullt1
1997 - 2003 F150
Jan 3, 2007 04:21 PM
