Oil system flushing
Old Aug 30, 2004 | 09:50 PM
Garland's Avatar
Garland
Oil system flushing
Is oil system flushing a good idea? And what are the benifits?
Old Aug 30, 2004 | 10:37 PM
rander101's Avatar
rander101
If you change the oil regularly and on schedule I can't see any advantage to oil system flushing.
Old Aug 30, 2004 | 10:58 PM
Garland's Avatar
Garland
I have a 93 mitsu diamante that was not taken car of very well before I got it. PCV system and all was so clogged up it blew the main seal out. Need to know just in case the same thing happens with this 80 F100 I just got.
Old Aug 31, 2004 | 05:03 AM
srercrcr's Avatar
srercrcr
I'll have to disagree. When you pull the valve cover, you'll see some degree of varnish for sure, and possibly some sludge (crud). That's the nature of hydrocarbon engines.
The flush is like kerosene. If you had greasy hands and put kerosene on them, the grease would melt away, just like the degreaser products do to the grease on your engine.
Old Aug 31, 2004 | 08:29 AM
fellro86's Avatar
fellro86
I stand withthe regular oil changes, I have disassembled many motors that look as clean as the day they were built, just because of regular service. The upper level of the valve covers may get varnish, but that is due to the cooler temps there, and it won't be the case further down, certainly not to the point of plugging. I have used trans oil instead of one of the quarts of engine oil to clean up abused engines, I would be concerned useing anything that destroys oil in a motor, as it destroys lubrication and cushion when it destroys oil. I made that mistake once on an Escort, it was so crudded up, used kerosene in it by the advice of my brother in law, and the engine was junk shortly after. I was still young and learning, but I will never do that again, I don't care how bad the motor is. If it is so bad that a method like that is the only salvation, might as well figure on tearing it down, as that will be coming anyway.
Old Aug 31, 2004 | 09:04 AM
holland501's Avatar
holland501
I wouldn't recommend a flush on an older engine. Put in a good quality oil and filter and let them do their job. The detergents will slowly and safely disolve any sludge and deposit them in the filter. The process will be slow but you can feel safe that you won't cause any new problems. Good luck.
Old Aug 31, 2004 | 12:50 PM
db_tanker's Avatar
db_tanker
I have always followed the advice to NOT flush a questionable engine. Just change the oil regular. If you try to flush, then you run the chance of clogging up your pick up screen. Run a good oil, like Castrol or Shell Rotella.
I run Rotella 15-40 in my 302 and Castrol 10-30 in my Mitsu. The Rotella, being diesel oil, has a much higher detergent content than normal gasoline motor oil. IMHO it is worth the extra 2 or 3 bucks at the Jiffy Lube.
Old Aug 31, 2004 | 03:57 PM
Garland's Avatar
Garland
I change my own oil. I used to use Castrol but don't anymore cause I've heard that it causes carbon deposits in the engine after being used for a long time. Don't know if theres any weigh to this statement but the engines got 250k miles and I don't want to take any chances. Still runs like a champ. Just the problem of them minor oil leak now from the rear main seal, and the noisy lifters, cause whoever owned it before I did didn't change oil at proper intervals.
socalfordguy2003
Aug 20, 2014 07:15 PM
jl4407
Aug 5, 2012 01:34 AM
johnsjsj
Jun 20, 2012 09:16 PM
PaulwestSki
18
Apr 29, 2012 04:58 PM
JonArmy
Mar 12, 2012 07:33 AM
