Replacing oil cooler..flush system
Old Aug 20, 2014 | 12:33 PM
socalfordguy2003's Avatar
socalfordguy2003
I heard that once oil cooler goes out and oil is in coolant. the coolant system shoud be flushed and all hoses should be replaced because the oil swells the hoses....any thoughts
Thanks
Old Aug 20, 2014 | 12:43 PM
Jmoen7's Avatar
Jmoen7
Once it blows your really deep in the doodoo.
Replace oil cooler, put back together, flush system thoroughly and keep it straight water, tear back down and replace the oil cooler again and then replace all hoses and degas bottle in the coolant system and then put back together and add your coolant and replace oil
Old Aug 20, 2014 | 06:26 PM
69cj's Avatar
69cj
I disagree. Replace oil cooler and hoses and flush with dawn detergent till water is clear then add your coolant 50/50.
Old Aug 20, 2014 | 07:15 PM
Jmoen7's Avatar
Jmoen7
Only speaking from posts i've seen. You can flush a perfectly well operating system and still plug an oil cooler, right?
FL SuperDuty
Dec 22, 2017 10:29 AM
ajsemtb
Apr 5, 2017 06:46 PM
Talyn
Jan 27, 2013 05:27 PM
Thermo2008
Aug 14, 2011 08:03 AM
bradfr
Mar 19, 2010 12:30 PM
