cab/firewall flex mechanical clutch
Old Jul 29, 2004 | 01:26 AM
dada's Avatar
dada
I have 1980 F350 4WD, just reinstalled my rebuilt 400 with new clutch and all... first off my bushings in the equalizer aren't quite right (from a kit I bought) it seems one of them should be cupped to accept the ball on the frame... the kit came with 2 rounded outer bushings that insert into the bar... anyhow it does drag a little, but is very sound (no play)...
anyway, when pushing down on the clutch pedal my whole firewall lifts up and flexes very noticably.... it is a mechanical clutch setup and it seems the pressure on the mount (attached to the firewall) is pushing the firewall and front cab outward and upward... I thought I read somwhere through the forums that bad body mounts can cause this... mine are pretty squishy and cracking...
Any thoughts are welcome... I am trying to square away this truck after investing in the motor and drive train rebuilds and want to make it right...
Old Jul 29, 2004 | 04:54 AM
Jimbare's Avatar
Jimbare
all alone in the world
it is the metal the firewalls are made of, way to light. i have seen several that were cracked, even saw one that was broken out around the booster.
i usually fix them with a 1/16 in thick peice of metal on the inside and the outside!
jim
Old Jul 29, 2004 | 05:48 AM
82F100SWB's Avatar
82F100SWB
My 82 F100 was like that, it was collapsed cab mounts, the entire corner of the cab would lift when you pushed in the clutch...
This is not even remotely related to the firewall flex the hyd. clutch trucks experience.
Old Jul 29, 2004 | 06:37 AM
wiseguy's Avatar
wiseguy
My '86 has a small crack in the firewall on the inside above the slave cylinder. I found it while trying to find a water leak. I guess I'll reinforce it one day, hopefully before it gives way.
Old Aug 21, 2004 | 05:37 PM
Katmandu's Avatar
Katmandu
E3TZ-7K509-A small kit.
E3TZ-7K509-B Big Kit
Old Aug 21, 2004 | 07:14 PM
jwrboss302's Avatar
jwrboss302
Hey Katmandu,
What is the difference between the small kit and big kit? I got a kit from Ford a long time ago, but it was not even close to fitting my truck 85 F250HD with 460. I never returned it because one of the service techs who I knew, just gave it me. The part number I got was E3TZ 7K509 A.
JWR
85 F250HD 4x4 460 T-19 4.10
Old Aug 22, 2004 | 07:04 AM
Katmandu's Avatar
Katmandu
Arrow
Originally Posted by jwrboss302
Hey Katmandu,
JWR
I copied this from another thread.....
the small kit consist of::
template for drilling correct holes.
4 bolts and nuts.
instruction sheet.
re-inforcement bracket.
large kit consist of::
instruction sheet.
large re-inforcment bracket.
hardware kits.
Anyone have pics of the re-inforcement brackets in these kits ??
Old Aug 22, 2004 | 12:14 PM
jwrboss302's Avatar
jwrboss302
I have the small kit in a box, I will try to post pics
JWR
85 F250HD
Old Aug 22, 2004 | 08:12 PM
Katmandu's Avatar
Katmandu
Arrow
JWR
85 F250HD
Would be very interested in seeing them.
Old Aug 31, 2004 | 01:26 PM
Katmandu's Avatar
Katmandu
Question
Where do these repair kits get mounted ??
On the Inside or the Outside of the firewall ??
Old Aug 31, 2004 | 04:11 PM
fellro86's Avatar
fellro86
They mount on the inside of the firewall, and are quite slick. I paid $15 for the small kit, which will work most of the time, unless you really have a bad case. Someone had tried to fix mine with big flat washers, which had helped, but wasn't quite enough. The install isn't too bad, the clutch master has to be taken loose, and then the plate is attached inside with 2bolts which the template shows where to drill the holes for, and then two more are supposed to be drilled, but I didn't feel like fighting to get a drill in the area to be drilled, so I just welded the plate to the firewall in that area. It made all the difference in the world.
four-sixty-power
Mar 19, 2017 01:44 AM
catto95
Jun 28, 2016 11:54 AM
mattri
Jan 15, 2016 05:40 AM
john.clark
13
Oct 12, 2015 03:14 PM
