Column shifter problems
Old Aug 29, 2004 | 10:56 PM
Cracker289's Avatar
Cracker289
My shifter was not working properly, at first I thought I had worn linkage or something, but with my son inside the cab shifting from "Park" to "Low", I could see the linkage off the steering column near the firewall only moves about 1 or 2 inches up and down, where it needs to move about 8 inches up and down. Is there a way to tighten this up, maybe it is slipping? My chiltons manual was totally useless.
Old Aug 30, 2004 | 08:42 AM
Jimbare's Avatar
Jimbare
all alone in the world
sounds like it is time for a rebuild. the shift collar may be worn out, or the shift arm may have come loose from the shift tube. no matter what you are gonna have to tear it apart and find the problem.
jim
Old Aug 30, 2004 | 08:03 PM
'70F100Owner's Avatar
'70F100Owner
Mine just did the same thing. A little piece on the shifter tube that slides i na notch on the shifter broke. 4 rivits later it shifts like new. Probabvly something simple, you will see when you tear it down. It is a 2 person job, 4 hands make it TONS easier to work on.
Old Aug 31, 2004 | 01:15 AM
Cracker289's Avatar
Cracker289
Sounds like it will a lot easier and faster for me to convert it to a floor shifter!
emeraldcoupe
13
Nov 15, 2022 10:04 PM
ferguson777
28
Mar 15, 2013 08:41 PM
lucaswitdalidoff
May 17, 2012 07:33 PM
ron65
Jan 6, 2007 04:06 PM
tvvbsn
1997 - 2003 F150
Apr 1, 2005 11:14 AM
