Aerostar Ford Aerostar
Rattling Door Panels
Old Dec 15, 2002 | 01:17 PM
shakespearesdad's Avatar
shakespearesdad
Help me! I have a 1996 Aerostar and the front door panels have come loose from nearly every attatchment point from the arm rests on down to the bottom of the door. The "plastic stud" is still attatched to the panel but it is poking into an open hole. What used to be in there? Any ideas about what to plug the hole with to be able to re-attatch the panels? Thanks in advance for any help.
Old Dec 16, 2002 | 10:02 AM
aerocolorado's Avatar
aerocolorado
Go to the dealer and request a couple of bags of 'door panel fasteners' (common name). They come in a pkg of 10 fasteners. You will note the new ones have serrated edges that grip the hole when pushed into place. Yours have apparently worn away most of the gripping edges as the panel flopped about on the door. To remove the panel, remove the screws attaching the arm rest, door latch and remove the window riser handle (if so equipped). The remaining panel fasteners are released using a gentle prying. A stiff scraper blade works well. Once the panel is off you can see where the new fasteners are required. They are designed as single use only items, for obvious reasons. Having spares around is advisable for once you start looking, you'll find more floppy panels.
The local Ford shop here charges $4.00 for a bag of 10 fasteners. Auto parts stores sell them in blister packs of 2, but seldom have more than 3 or 4 on hand and by the time you accumulate 10 the price is nearly double the dealer cost. Some auto-body shops also carry these but again it seem hit or miss as to whether they have the right version and quantity needed.
Old Dec 17, 2002 | 10:32 PM
shakespearesdad
Thanks for the help. I was just about ready to over-engineer a solution to this problem! Your idea is a lot easier than what I was about to do!
Old Dec 17, 2002 | 10:40 PM
rebocardo's Avatar
rebocardo
While you are at it, get a trim panel remover so the old clips do not damage the panel when you pull it away from the door.
Old Dec 18, 2002 | 08:19 PM
biederboat's Avatar
biederboat
The door panels commonly break behind the arm rest from too much flexing. I installed some self drilling/tapping trim screws that look good enough and really beef up the panel.
Mark
Old Dec 19, 2002 | 02:41 PM
WWildbh's Avatar
WWildbh
Roelito78
42
Nov 6, 2010 07:02 PM
loneleader
Mar 4, 2006 11:58 AM
Viper6
Mar 26, 2005 11:47 AM
JJFL99PSD
May 4, 2004 03:09 PM
