Sponsored by: Real Truck
Insterment cluster
Old Aug 26, 2004 | 02:10 AM
TCELasVegas's Avatar
TCELasVegas
Angry Insterment cluster
I need help I put my 2000 Ford 4x4 crewcab daully in park and all the gauges went dead including the tack and spedo as well as a few of the deummy lights. Any ideas????
Old Aug 26, 2004 | 07:51 AM
Pocket's Avatar
Pocket
Check your fuses?
Old Aug 26, 2004 | 08:04 AM
TCELasVegas
Have already done that there all good
Old Aug 26, 2004 | 09:39 AM
Big Orn's Avatar
Big Orn
Have you followed the wiring down the steering column? I seem to remember someone having frayed wiring in the column causing them problems.
Old Aug 26, 2004 | 01:33 PM
Pirate16's Avatar
Pirate16
try taking the dash apart and getting to the gauge pod, on my jeep it was a complete pod that plugged into a plug mounted on a bracket and it didn't have any clips or anything to hold the gauges in so they would seperate and the gauges would die. i don't know how ford does it but it is worth a try, or atleast push on the front of the gauges and see if you can get them to reseat.
Old Aug 26, 2004 | 11:27 PM
myfordf350's Avatar
myfordf350
Sounds like a fraid Wire to me.
Take the steering parts apart and look for a fraid wire. Ford techy should be able to figure it out.
Ken - THE HIGH COUNCIL
Old Oct 2, 2009 | 04:17 PM
GreenF350DRW's Avatar
GreenF350DRW
I have a 2004 F350 DRW Diesel, I would be driveing down the road and my instament panel would die or flicker on and off. I noticed that this would happen when the temp outside was cool and the engine was at idle or low RPM. What was happening was the 6G alternator was not putting out 14 volts this would cause the relays to switch when I had a load on the electical system. Lights on or just the radio going. To test your Truck hookup a volt meter to the cigarette lighter and monitor your trucks voltage if it drops below 13.5 volts the electrical system will start up with problems. I replaced my alternator with a large housing H/D high output alternator 160W. Ran a secoundary fused hot lead from the alternator to the battery and a ground from the alternator to the neg post of the battery. I now can run the heated seats the lights the radio and the wippers all at the same time with no problem.
joeskeeter
Feb 21, 2008 10:23 AM
nobull4x4
Jan 23, 2005 03:55 PM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
4x4x4x4
Sep 30, 2002 03:55 PM
stoab
Sep 10, 2002 01:13 AM
