73 fuel pump
Old Aug 25, 2004 | 11:20 PM
toyotaguy's Avatar
toyotaguy
73 fuel pump
is a stock fuel pump on a 351w adiquite to handle a 650 holley with a recurlating fuel system? when im ont the throttle it seems to hesitate a little. what do you guys think?
thanks
justin
Old Aug 26, 2004 | 08:12 AM
73Custom's Avatar
73Custom
My stock pump on my '73 handles the 390 and Edelbrock 625 with no problems - but I don't have a recirulating fuel system.
Marty
Old Aug 26, 2004 | 06:22 PM
73effie's Avatar
73effie
what would a recirculating fuel system be? i think my 73 has one
Old Aug 26, 2004 | 07:25 PM
toyotaguy's Avatar
toyotaguy
re circ
A re circ fuel system is prety cool if you have problems with vapor locking. all it is is a tee in line after the fuel pump and one side goes to the carb and the other goes back to the tank. thus giving you cool fuel keeping it from boiling in the lines. my system has a 1/4 inch return line that i crimped down about half way. so i was wondering if any one knows the specs of a stock fuel pump. aka gpm.
thanks
justin
Old Aug 26, 2004 | 07:49 PM
LxMan1's Avatar
LxMan1
If it is in good shape, it should be good enough to keep the carb full. I would look into the timing and accelerator pump for the hesitation problem. It if was a feulpump problem, it would run out of fuel at the top of each gear.
Old Aug 26, 2004 | 09:18 PM
73effie's Avatar
73effie
does it have a return line to the tank? looks like its set up so when the bowl is full then the fuel is pumped back to the tank. can i get rid of this system if i ever had to?
Old Aug 26, 2004 | 11:30 PM
toyotaguy's Avatar
toyotaguy
return line
yes you can ditch that system, but if you do you could possibly encounter vapor lock during long pulls up hills in hot weather.
Old Aug 26, 2004 | 11:34 PM
toyotaguy's Avatar
toyotaguy
timing
dose any one know what the timing is on a 351w
thanks
justin
Old Aug 27, 2004 | 07:42 PM
73effie's Avatar
73effie
thanks for the info, appreciated
eddie-
Old Aug 29, 2004 | 11:39 AM
LxMan1's Avatar
LxMan1
8 to 10 BTDC would be a good place to start on the timing.
2duff2
Nov 7, 2016 11:40 PM
jspringator
May 17, 2016 09:24 PM
creedua
Sep 20, 2015 06:06 AM
Ratsmoker
Jan 1, 2003 08:10 PM
steve_
Bronco II
Mar 29, 2002 04:09 PM
