Play in 1356 transfer case
Old Aug 25, 2004 | 10:06 PM
broncobasher's Avatar
broncobasher
I have an 1990 F150 with a Borg Warner 13-56 transfer case in it. I get a fairly loud clunk when putting in gear or going from drive to reverse or visa versa. I have determined that the play is within the x-fer case. I took the drive shaft loose and removed the tail shaft extension. I then turned the shaft by hand and can feel and hear the play within the case. It seems to work fine. Can this play be a problem? Will I have to replace gears within the case to fix the problem? Or is it possible that bushings or bearings are worn causeing the back lash within the gears?
Thanks,
BroncoBasher
Old Aug 25, 2004 | 11:06 PM
FordPerf300's Avatar
FordPerf300
Might be time for a rebuild, bearings, pump and chain and you'll be on your way. Pretty easy to rebuild from what i hear.
Old Aug 26, 2004 | 07:14 PM
broncobasher
You think the rebuild will take the play out? I have found a complete rebuild kit for like $120, but it only has bearings and seals, no gears.
BroncoBasher
Old Sep 9, 2004 | 09:43 AM
edwardldog's Avatar
edwardldog
Question awww man
Hey Bronco basher
Dude have you found out anything Yet????? I also have a 1356 Borgwarner in My 88 F350 Diesel and lost Low range this last weekend... and also have been told Bearings and seals........ have you tore this appart Yet.... have you found an acceptable source for parts Yet....
hanks Bud
Standing on pins and needels
Old Sep 9, 2004 | 12:45 PM
edwardldog's Avatar
edwardldog
Thumbs up found info
Hey Bronco Basher check this out I found some good info on another post..
http://www.wildercafe.com/fordtech/
http://www.wildercafe.com/fordtech/Thumbnails.asp
http://www.drivetrain.com/bw1356transfercasesillust.htm
Check them out you will be pulling it and tearing it down..
Old Sep 9, 2004 | 06:25 PM
broncobasher
Already found both of those pages. Hehe, thanks. No, I am still driving it. I'll get unlazy one of these days and pull it. I guess I better hurry up, hunting season is approaching fast. Someone else told me that maybe I have a bad tooth on the planetary gear set on the input/rear output shaft. I'll let you know when I find out for sure.
mr1
Sep 10, 2016 10:38 PM
1972RedNeck
Mar 1, 2016 05:06 PM
biederboat
Mar 18, 2010 08:31 AM
broncobasher
May 28, 2004 08:45 PM
broncobasher
Electrical Systems/Wiring
Nov 20, 2003 01:07 PM
