Need help with leaking 1356 transfer case
Old Sep 10, 2016 | 07:56 PM
mr1's Avatar
mr1
I have a '92 f150, extended cab with borg warner 1356 t.c. Transfer was leaking at the rear output seal. Found bad center support bearing also had damaged drive shaft in center support area. Had drive shaft repaired, shaft was balanced and new u-joints, new center support bearing. The repair shop told me that the slip yoke was still good. I replaced the seal and there is no play in the slip yoke bushing. Installed everything and go for a short ride and the seal is leaking again. Any ideas?
Old Sep 10, 2016 | 10:38 PM
xrsfsho's Avatar
xrsfsho
is the lip on the seal not damaged from install or maybe it folded in. that's the only thing I can think of at this moment. or a small gouge in the slip yoke but you said it is fine
1983F1503004x4
Nov 18, 2022 05:41 PM
Ford Fx4
Mar 3, 2010 11:02 PM
nzabka
Apr 18, 2006 04:28 PM
95f150
May 15, 2005 08:55 AM
Skagit
Nov 29, 2003 09:15 AM
