Sponsored by: Real Truck
clunking around tight turns
Old Aug 24, 2004 | 10:47 AM
sillyp's Avatar
sillyp
I'm hearing a mild clunking noise when doing real tight turns in parking lots. thinking maybe its a ball joint. but it seems like it does in more when the hubs are locked.
99 F250 superduty 4x4
Old Aug 24, 2004 | 10:50 AM
jake00's Avatar
jake00
i just bought my 02 and I have the SAME EXACT noise, yes, mine does it more with the hubs locked too
I'm thinking about taking mine in to the shop, since my hubs are frozen
Old Aug 24, 2004 | 12:54 PM
sillyp's Avatar
sillyp
hmm, could it be those u-joints on the axles?
Old Aug 24, 2004 | 01:29 PM
Big Orn's Avatar
Big Orn
Probably not.
Have you checked the ball joints? When you have the tcase engaged and the hubs locked it puts more than usual stress on the ball joints when turning, causing them to sound off more.
check the ball joints, first.
Let us know.
Old Aug 24, 2004 | 02:01 PM
sillyp's Avatar
sillyp
ok, how do i check them? With my other cars, you just get the wheel off the ground and then push/pull on the top and bottom of the tire and see if there is any play. I haven't gotten a haynes manual for this truck yet.
Old Aug 24, 2004 | 03:15 PM
Big Orn's Avatar
Big Orn
Same principle. Just make sure you have the front diff secured. You could need some help here and a prybar. Let them move the wheel up and down with the bar while you check the ball joints from underneath.
With that sort of noise it would be evident. Also check the shocks and shock brackets while you're under there as well as the ujoints - just in case.
Aune163rd
Modular V10 (6.8l)
Aug 15, 2012 06:57 PM
MDSuperDuty
Dec 5, 2011 07:37 AM
fordex2003
Mar 3, 2010 01:44 PM
Navyguns
Aerostar
Nov 9, 2008 10:34 PM
ph1946
Mar 29, 2008 04:34 PM
