Front suspension knock
Old Mar 28, 2008 | 10:51 PM
ph1946's Avatar
ph1946
I'm getting a knock or clunk from front end when making tight turn with my 94 F-150, 4.9 with 101k miles. Either direction...... ??????????
Old Mar 29, 2008 | 02:49 AM
redrush40's Avatar
redrush40
Ok dude,
make sure you don't have the front manual hubs locked.
make sure your tie rod ends/steering components are good (no play) as well as greased up.
does it make a noise when you turn all the way to one side (wheel locked).
TONY Z.
#40
Old Mar 29, 2008 | 10:10 AM
ph1946's Avatar
ph1946
No hubs.........2WD........ not necessarily locked, but close. Just tight turns in either direction
Old Mar 29, 2008 | 10:20 AM
frederic's Avatar
frederic
Radius bushings and pivot bushings are made of rubber, and deteriorate over time, allowing metal to bang on metal. Check them as well. Could also be loose shocks, ball joints, etc. Lots of things in a front end to work loose, rot, and fall apart.
Old Mar 29, 2008 | 03:29 PM
Firemedic417's Avatar
Firemedic417
Found reason for mystery clunk on 97 f250
I had a clunk coming from what felt like the upper right area when turning and hitting a bump, no clunk at all when going straight over any bumps. I looked around the right front for a while and all looked good. Something told me to check the left side and sure enought discovered the sway bar link was broken on the LEFT side. I was positive the clunk was coming from right front.
So, I went to AutoZone and for $20.00 got two links (replaced both sides since other one will probably break also) and now there is NO MORE CLUNK!
Old Mar 29, 2008 | 04:34 PM
Jason Lewis's Avatar
Jason Lewis
Radius Arm bushings
My truck was bad about those after i got it new so far so good on this set.
reboswon
Escape & Escape Hybrid
Jan 25, 2011 06:26 AM
cleaningbug94
Nov 8, 2010 10:04 PM
joe68
1983 - 2012 Ranger & B-Series
Jan 8, 2009 08:01 AM
Neptune
Apr 18, 2006 01:21 PM
