5.4 mpg!?!?!?!?
Old Aug 23, 2004 | 03:59 PM
agloop's Avatar
agloop
Red face 5.4 mpg!?!?!?!?
I just bought a 71 F100. It's my first truck, and it runs really well. The only big surprise was the gas mileage (5.4 mpg -- does that sound right?) Glad to be on the site.
Old Aug 23, 2004 | 04:04 PM
gtex's Avatar
gtex
sounds right if you're running a hot 428, 44" boggers and 7:1 gears.
In other words. That sounds low. Most of the combinations are good for 10-15 MPG if tuned properly.
tell us more about your motor, tranny, axle ratios and tires.
Old Aug 23, 2004 | 04:19 PM
agloop's Avatar
agloop
I first have to say that I'm not that knowledgeable about this stuff. Here's what little I do know: The engine is a 360. It's 2WD. It has headers. The original carb was replaced with an Edelbrock 600 cfm. The tires look a little bigger than the original tires would have looked, but not absurdly large. Other than that, I don't think too much was modified from the original.
Old Aug 23, 2004 | 06:11 PM
gtex's Avatar
gtex
As an F100, the stock gear ratio should not be too bad for mileage.
Taller tires should actually help a little with mileage unless they are very tall and wide (heavy).
Sounds like your 360 needs some tuning. Start with the ignition. Make sure all the components are in good shape, clean connnections and then check to see waht your initial timing advance is. You'll want it to be about 10 BTDC.
Check out the FE engine forum (a little farther down the main forum page) for more info about the engine. Use the search feature to find many threads on tuning and mileage.
Old Aug 23, 2004 | 11:48 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Aug 24, 2004 | 07:30 PM
rebocardo's Avatar
rebocardo
Speedometer could be wrong.
Old Aug 26, 2004 | 08:55 PM
baitmaster's Avatar
baitmaster
I confess, I've been siphoning 5 gallons a night out of your truck!
Old Aug 26, 2004 | 09:22 PM
gtex's Avatar
gtex
Yeah, that could be a problem....I was taking 5 as well.
