Diablo Predator Tune - OK for towing on my Expy?
Hi;
Just wondering if the Diablo Performance Tune included with the Predator is suitable for use while towing? I looked at the documentation and the web site, but saw nothing related to this question?
I have installed the tune on my 2000 Expy and so far am happy. It does feel like there is a power increase, but 10-20 horses is really tough to feel in the seat of the pants. The transmission behaviour however is improved quite a bit and well worth it.
I look forward to more driving time to get a better feel for it. I also need to get better 91 octane fuel as I had to retard timing by 8 degrees just to stop the pinging under acceleration...
Eric
Eric
Hi Claynewt;
I had to reduce the timing as you can see by this thread, but I also upped the torque modulation for the transmission to 100% to avoid as much slippage as possible during up shifts and adjusted the shift firmness to 50%. I have not towed yet however (next week) so I don't really know if these values are better or worse since these items will show mostly under load or WOT I gather.
With the basic tune though I did immediately notice that the shift behaviour of the transmission had changed for the better. It is not so quick to upshift into a higher gear at slow speeds. I also noticed what I perceived to be better acceleration however I won't really be able to confirm that 100% until I can get a tank of 94 octane into the truck and advance the timing back up to where it should be.
Now if only the Predator could program my overdrive to stay off until about 80KPH (50mph) I would be a very happy camper...
Cheers;
Eric
P.S. Let me know what you find/think when you get to testing your setup...
Cheers;
Eric
Racer944....Check out my thread "kit or tune for firm shifts"...I'm getting feedback from Ken about modifying tranny parameters. I have wound mine up a couple of times and found out that it does make it move, sound, and shift better! I'm able to use BP/Ammoco 93 octane w/o any pinging (17 gal. on top of 8 gal. of 87 octane). You should notice a big difference once you can take full advantage of the tune!
Hi Ken (and Claynewt);
Tanked up with Sunoco Gold 94 Octane and was able to reset all Diablo tune timing parameters back to where they should be (i.e. no retard necessary).Truck is responding very well to the Tune!!
I am happy with the performance gains/feel of the truck, and I am very happy with the transmisson behaviour now...
Thanks for your help guys.
Cheers;
Eric
P.S. Only wish Diablosport had included a few small stickers in the box! ;-)
Cheers;
Eric
