trans problem
Old May 14, 2000 | 12:14 AM
91xplorer's Avatar
91xplorer
trans problem
i have a 91 explorer 2wd when it is cold it stays in 1st gear.but when it is warm somtimes it will shift fine when i drive it and stop it does not go all the way into first gear but sometimes it does but kicks right out of first.i change the fluid and filter.DOES ANYONE KNOW WHAT CAUSES THIS OR I CAN FIX IT
Old May 14, 2000 | 10:09 AM
PAUL_2's Avatar
PAUL_2
trans problem
We need to know what transmission is in your Explorer ?
Paul
Old May 14, 2000 | 10:36 PM
91xplorer's Avatar
91xplorer
trans problem
it is a a4ld
Old May 16, 2000 | 08:56 AM
PAUL_2's Avatar
PAUL_2
trans problem
The A4LD is the only Explorer trans that is not computer controlled . It uses a vacuum diaphram ( Modulator ) Its possible yours is having a vacuum problem or the modulator itself is failing . Its a simple repair if thats the problem . Im not a transmission specialists . Best advice is have a tech that deals with transmissions all the time have a look and make a diagnosis .
Paul
Old May 20, 2000 | 07:24 PM
PAUL_2's Avatar
PAUL_2
trans problem
zmorby91
Apr 30, 2017 11:47 PM
Tnhill
1978 - 1996 Big Bronco
Feb 9, 2017 02:28 PM
Broncogirl91
Jul 16, 2016 07:38 PM
Plowboy34
Dec 7, 2015 09:39 AM
morepower16
Sep 17, 2002 05:14 PM
