Help
Old Aug 22, 2004 | 08:24 AM
death's Avatar
death
Help
I have a 1990 f150 four wheel drive 300 engine with efi. I had the motor rebuild by a person that has rebuild a lot of engines. It hard for me to think all 6 fuel injectors are bad at the same time. Its try to start but will not. But every thing looks good I have never seen all six injectors go at the same time.The fuel rail has 50 to 60 psi and the injectors are getting power. Please help are my over looking something
Old Aug 22, 2004 | 02:00 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Check the distributor timing. Pop the dist cap off and see that the rotor is pointing to cylinder #1 when #1 is at TDC on the compression stroke. Also check to see that you have juice to the coil and spark at the plugs.
Old Aug 22, 2004 | 06:02 PM
death's Avatar
death
Thanks
Yes the rotor is pointing to cylinder number one when the number one is at TDC on the compression stroke and yes there is good spark at the plugs nice blue flame. thanks
Old Aug 23, 2004 | 03:53 AM
GermanGuy's Avatar
GermanGuy
Are the ignition leads connected to the distributor in the right order (correct firing sequence)?
Dieter
Old Aug 23, 2004 | 02:03 PM
death's Avatar
death
Unhappy
Yes sir I have checked it and checked again. I think I will put all new injectors in it thats what I think it is. All the test I did point to that but I have never seen all of them go at the same time.
Old Aug 23, 2004 | 02:05 PM
death's Avatar
death
Smile
Thanks too all that replied to this I will let you know what happens thanks again <TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><!-- / subject field --><TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><TABLE class=fieldset cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD></TR></TBODY></TABLE><!-- / subject field --><!-- / subject field --><!-- / subject field --><!-- / subject field --><!-- / subject field --><!-- / subject field --><!-- / subject field --><!-- / subject field --><!-- / subject field -->
Old Aug 23, 2004 | 02:59 PM
Crazz's Avatar
Crazz
Thumbs up compression test
did you try a compression test ?
Old Aug 23, 2004 | 03:01 PM
andym's Avatar
andym
All six fuel injectors did not go bad at the same time, I'll just about guarantee that.
Old Aug 23, 2004 | 03:16 PM
death's Avatar
death
thats what I say but the test point to it
smitty403
Mar 10, 2014 03:24 PM
turp
Jan 20, 2013 01:40 PM
catman52987
Jan 29, 2012 10:37 PM
Putnam96
Sep 22, 2010 04:00 PM
coldnorthpole
Mar 3, 2007 07:19 AM
