exhaust smoke
Old Sep 22, 2010 | 11:07 AM
Putnam96's Avatar
Putnam96
exhaust smoke
Hello first time on here so hope to get some help.
I have a f-350 pickup with diesel 6.0l engine. The engine hydro locked from fuel. I have it at a ford dealership with a friend working on it on the side. Changed all the injector out with rebuild ones. Truck runs now but have a white fuel smoke out the exhaust all the time. What could be the problem. The ford mechanic has no idea why its still smoking and he works on diesels all the time. Please help
Old Sep 22, 2010 | 11:59 AM
dchamberlain's Avatar
dchamberlain
Are you sure it's fuel smoke?
What does it smell like? It may be coolant from a failed EGR cooler.
Old Sep 22, 2010 | 03:03 PM
Putnam96's Avatar
Putnam96
Im sure is not a failed egr cooler. I have pulled the EGR value and checked the intake no sign of coolant there. The smoke will make your eyes tear and smells like raw fuel.
Old Sep 22, 2010 | 03:29 PM
m-chan68's Avatar
m-chan68
IDS Power Balance, relative compression (and may manual compression ets if necessary) and fuel pressure tests. Infrared temperature gun at each exhaust manifold port and/or exhaust manifolds loosened from cylinder heads with the engine running to see which hole is smoking.
Old Sep 22, 2010 | 03:31 PM
m-chan68's Avatar
m-chan68
How long was the engine run for after replacement of all eight injectors? If it was overfueling that bad as you described to the point of hydrolocking the engine you will have A LOT of residual raw fuel left in the exhaust to burn off, as well as some base engine damage has likely occured.
Old Sep 22, 2010 | 03:55 PM
Putnam96's Avatar
Putnam96
The exhaust muffler has been removed the exhaust is dry. It had 4 time the fluid in the oil pan from the fuel. The truck has made one 45 min drive from the dealership to my house, there it sits. I have found a longblock engine for $3900 was thinking of changing the motor out. just hope the part that need to be moved from the old motor to the rebuild one is not going to move my problem as well.
Old Sep 22, 2010 | 04:00 PM
m-chan68's Avatar
m-chan68
If you do go ahead with the swap, you'd better hope the donor engine is from an identical model year to avoid headaches.
dynarider33
Aug 28, 2014 07:52 PM
linus72
Apr 16, 2012 07:40 AM
C9ZZ
6.4L Power Stroke Diesel
17
Feb 4, 2011 12:53 PM
JudgeRC
23
Mar 27, 2009 07:51 PM
lwhitley
May 11, 2006 05:50 PM
