alternator question..need help
Old Aug 19, 2004 | 10:09 AM
sidala's Avatar
sidala
Question alternator question..need help
is there anyway to tell what alternator i have i saw it could be a 95 amp or a 130 amp and i need a voltage regulator for it and i would like to get it before i remove the alt so i have it here also do i ned to replace brushes when i do this or are they included and it just bolts right on. thanks for any help i had never done this before so i want to make sure before i remove it
Mike
1992 E150 coversion van 302 v8 with a/c
Old Aug 19, 2004 | 07:27 PM
trike1946's Avatar
trike1946
In my 92 6 cyl., the voltage regulator was part of the alternator if I remember right. You do not have to replace brushes, it just bolts on. You may have to go to the parts store and match up the alternators to see which one you have. Take your time, it is an easy fix. Watch which way you take the belt off. Good luck with it.
Old Aug 19, 2004 | 07:47 PM
94van's Avatar
94van
The replacement alternator comes ready to bolt on. There should be some numbers stamped in the alternator housing, of which one set should show the amp of that alt.
adamsrancho
Jun 21, 2024 07:16 AM
coolfeet
Mar 6, 2018 08:07 PM
kbarbee95
Jul 9, 2015 03:10 PM
79f250camper+Lar
Electrical Systems/Wiring
Oct 15, 2006 07:58 PM
firedudecndn
Mar 14, 2005 05:27 AM
