Air Conditioning problems
Old Aug 21, 2004 | 05:12 PM
Librac23's Avatar
Librac23
when I jumped the switch, yes it stayed on, same as when I jumped from the batt. to the electric clutch connector
Old Aug 21, 2004 | 05:30 PM
TigerDan's Avatar
TigerDan
If you jumpped the pressure switch and the compressor stayed on, but you are getting a pressure of 45 psi at the low side, you probably have too much pressure, which will also kick off the compressor in order to keep from blowing out a hose or seals...or the compressor itself. You really need to get some high side readings, that will tell us more. To do that, you need a full A/C gauge set, not just the little low side gauge. Maybe a trip to a shop is in order. Here is a link to an A/C forum that has helped me a lot. -TD
http://www.ackits.com/forum/categori...id=2&zb=622553
Old Aug 21, 2004 | 05:41 PM
Librac23's Avatar
Librac23
Question Ac Prblms
thanks for the link,
The can that I used..obviously had the low side gauge...45psi is the max on its little "chart" they have to let you know if its full or over..or even dangerously over. @ first I had it in the middle of this little chart...about 30...nothing. put more in..to about 40..still...nothing...@ about 43-48 psi...the clutch for the AC kicked on...and it started to cycle..but it didnt get cold.
and when it did cycle...it was cycling the system rather quickly
I dont know...I think I will just leave it for now..and deal with it next summer
Old Aug 22, 2004 | 08:57 AM
ol yeller's Avatar
ol yeller
it will cycle
it'll do that until it maintains the pressure. urs should take about 3 cans. it'll tell you under the hood in most cases. son's 89 took 3 1/2 too blow cold.
Old Aug 24, 2004 | 05:28 AM
Librac23's Avatar
Librac23
Exclamation Ac Cycles but now leaks down
It cycles, but now I think I have a very slow leak. Cause now..it wouldnt kick on till I added more...
I guess I will try and change the hoses out and the intercooler to see if that helps fix the leak..and I will purchase some more new O-rings as well
whats the best way to lube O-rings for ac units? some lite 3-in one oil?
Librac23
Old Aug 24, 2004 | 05:30 AM
Librac23's Avatar
Librac23
Info under hood
3.5 cans you say?....Hmmmm will have to check into that...and where under the hood will it tell me?
Old Aug 24, 2004 | 09:50 AM
TigerDan's Avatar
TigerDan
Librac23
The A/C forum that I posted the link to has a very good online store for A/C parts, they recommend, and I tried and liked, a product called Nylog O-ring lube that is made for A/C. When you replace your O-rings, make sure you get HNBR rubber o-rings, not just regular o-rings. They are usually green, most parts stores carry them. When you open the system, plan on doing your o-rings all at once and then close everything back up again ASAP. When moisture gets into the system, you will have to replace the drier. It is recommended to replace it any time you open the system, but if you do it on a warm, dry day (do you have high humidity in your area?) then you should be able to get away without replacing it. Do one componant at a time, and be careful not to lose any oil out of the system. After you are done, you should take it to an A/C shop and have the system evacuated. They will hook a vacuum pump up to it and pull it down to about 29.9 HG and hold it there for about a 1/2 hour to an hour. This draws moisture and air out of the system and tests for leaks. Then charge it, and if you are lucky it will all work OK. A/C can be touchy. Read all you can in the A/C forums before you start. Good luck! -TD
Old Aug 25, 2004 | 11:53 PM
Librac23's Avatar
Librac23
Arrow Leak down Testing
well. I live in North West Minnesota...it can get rather humid....and that all depends on the day. but thats anywhere really...LOL
But thank you for that tidbit...it was quite informative...I forgot about having the system evacuated...and yeah..I am all to familliar with the special green O rings....a little on the spendy side...
But since I only replaced the canister..and Pump orings and didnt even crack open the lines between the cooler and the rest of the system...is it still a good chance there is a leak there? Cause I dont know if the system has ever been opened....cause I bought the truck used...and even then it didnt work
SO...I will have a tech do the evacuation test...I'm quite sure there is a crack somewhere.
Thanks again
Old Jul 25, 2010 | 07:49 PM
benbaronaa's Avatar
benbaronaa
1999 f 250 t diesel
my ac blows hot when i idle or decelerate. sometimes on the open road. how do i fine tune it to stay working more reliably?
Old Jul 27, 2011 | 12:50 AM
OSSKOBRET433's Avatar
OSSKOBRET433
Started truck . turned ac on .came back five min later . ac was blowing hot air , smelled something funny ,turned off motor poped hood saw a faint trail of smoke comming from area around compressor , had wife cycle control on and off while watching clutch and it does not seem to turn very fast. left it alone put a large can of 134 in and it slowly stated coming back. drove home from lake havasu and it worked fairly well , then today on a short trip it started to blow cold then hot then had the funny skunk smell again. any ideas ? 2005 6.0 psd excursion
scott79
Jun 13, 2021 02:05 PM
PasoF450
6.7L Power Stroke Diesel
Mar 5, 2017 04:13 AM
martyshel
May 7, 2015 10:44 PM
nebechanezer
May 26, 2012 06:34 AM
Sturge
Aug 16, 2005 11:29 AM
