ABS, light is blinking
Old Jul 25, 2011 | 10:38 PM
Dutter's Avatar
Dutter
What dos ABS mean and why is it blinking, I noticed it on my way home from gettin a friend of mine get unstuck, its a 4.0 auto tranny
Old Jul 26, 2011 | 02:48 AM
michigan66's Avatar
michigan66
A blinking ABS light is telling you there is something failed in the RABS system. Take the truck to a dealer or brake repair shop and have them read the trouble code to find out what has to be replaced or repaired.
Old Jul 26, 2011 | 12:44 PM
Dutter's Avatar
Dutter
Ok so its something to due with my brakes, I know my front pads are getting alittle low, could that be it, I
Old Jul 26, 2011 | 02:33 PM
michigan66's Avatar
michigan66
The ABS or RABS system is the Rear Antilock Brake System.
It prevents the rear brakes from locking up, so it has nothing to do with the front brakes.
You need to get someone to download trouble codes for the rear brake system.
Old Jul 26, 2011 | 05:55 PM
Dutter's Avatar
Dutter
Alright,, do u think autozone could help me on that
Old Jul 26, 2011 | 08:27 PM
michigan66's Avatar
michigan66
No, you need to go to someone with specialized equipment such as a brake repair shop or a Ford Dealer. A scanner that is different from the one that reads "check engine" light codes is needed.
Check the brake fluid level in the master cylinder reservoir first. A low level of fluid can cause your ABS light to turn on. If that is not the problem, you will need some specialized help. I've just gone through that, myself.
Let us know what you find out.
Old Jul 26, 2011 | 11:59 PM
Dutter's Avatar
Dutter
Weellll luckly i decided to check my fuses first, and guess what i had a blown fuse and put in a new one and waalllaa the light went away
Old Jul 27, 2011 | 01:10 AM
michigan66's Avatar
michigan66
Glad to see that you have the problem fixed. Any idea why the fuse blew?
Old Jul 27, 2011 | 11:38 AM
Dutter's Avatar
Dutter
Wheel my buddy went wheeling and got stuck in a real tight spot so i really had to yank him out hard and had to do it a few times in different spots, and thats pretty hard on a truck so thats my only guess, but hey he was so happy to get out of there because the rangers were on there way, he quick gave my a 20 and took off, then on the way home i saw him blasting up to were we were, But the guy didnt take down my plat numbers because i was only tryn to get this guy out
cptaylor
Feb 10, 2015 12:46 PM
1990f150dude
Oct 8, 2012 07:00 PM
EJ in CJ
1997 - 2003 F150
May 8, 2005 04:30 PM
F250duke
Sep 3, 2004 09:52 AM
Whitebassist
Aug 28, 2002 10:34 AM
