Tranny Temp Gauge E4OD
Old Aug 17, 2004 | 04:57 AM
missouguy's Avatar
missouguy
I tried this in transmissions, but got no response. Maybe here:
I put an Autometer tranny temp gauge in my F-250 E4OD trans. I put it in the test port. I have been hearing alot of debate about this.
When running on a hot day around town it will indicate around 180. If it is cooler, it will show around 160. If I am pulling on a hot day it will show 195-200. If I'm towing in cooler weather it will show 160-180.
Are these accurate temps for this tranny?
Thanks for the input.
Frank
Old Aug 17, 2004 | 08:39 AM
larry derouin's Avatar
larry derouin
Sounds good to me. Anything over 200 is BAD! But you're towing in hot weather and it doesn't get above that so you're probably ok.
I take it you have an aux cooler other than the factory "in the radiator" inline??
Old Aug 18, 2004 | 12:12 AM
missouguy's Avatar
missouguy
Yes it has the aux cooler you used to get with the towing package.
Thanks for the response.
Frank
shuttlevalve
Jun 16, 2010 06:35 PM
Crew-it
16
Mar 8, 2010 07:10 PM
DaBigTow
May 25, 2005 05:02 PM
bigbadjs
Sep 16, 2003 11:21 AM
GarrettRacing1
Nov 19, 2002 08:05 PM
