Testing fuel pump assembly before installing
Old Aug 18, 2004 | 12:29 AM
mike L's Avatar
mike L
I have an 1987 ford f150, dual tanks, 4.9, regular fuel and 2X4. How can i test my fuel pump assembly, before i install it?? Under FTE search I found
Quote
Checking the fuel pump assembly fuel pump, use a set of jumpers and a battery, and a bit of hose. Place a hose onto the output of the assembly, and immerse the strainer/pick up into a pail of non flamable, varsol and connect the jumpers to the battery and pump. Quote
Can i use diesel fuel to test the assembly, non flamble?? To test the assembly do i need to ground the pump unit, how? I have a four pin connecter two wires to the strainer ( red and black), one black wire to the float and one empty pin, is that the ground??
FORDF250HDXLT
117
Feb 10, 2025 11:29 PM
Jymmm
21
Apr 3, 2019 12:52 AM
NotEnoughTrucks2014
Jul 11, 2014 12:58 PM
h20_guy33
Sep 3, 2013 09:00 PM
INKAHOOTZ
Aug 26, 2009 04:41 PM
