Valve Covers
Old Aug 16, 2004 | 02:48 PM
jdwitte's Avatar
jdwitte
Valve Covers
I have an 87 Ranger w/ 2.9L V6 I have relplace the valve cover gaskets 3 times and always end up with a leak. I have been using cork gaskets but was wondering if the rubber gaskets were any better. My local auto parts store has Victo-Tech gaskets and said that they would work a lot better. Any opinions?
Old Aug 16, 2004 | 03:20 PM
Rockledge's Avatar
Rockledge
Fel-Pro makes an excellent gasket for your application, not the cork ones, but the PermaDryPlus Gaskets (Part # VS 50312T - Ford Truck 2.9L V6 1986-92).
If you read through this you will see that the above-referenced gasket is especially made for addressing issues associated with the 2.9L valve covers: Fel-Pro PermaDry Plus Gaskets
I put a set of PermaDryPlus valve cover gaskets on my 4.0L recently which are similar to the 2.9L gaskets.
P.S. Make sure the valve cover flanges aren't warped.
Old Aug 16, 2004 | 03:25 PM
ol yeller's Avatar
ol yeller
same here
we have had the same problem. going with the fel pro next time.
Old Aug 16, 2004 | 03:34 PM
Help I M Stuck's Avatar
Help I M Stuck
Use FEL-PRO..and make sure all surfaces are CLEAN. I use brake clean after geting any old seal off..spray it then wipe it clean then spray it and let it dry. I also use a little sealent..not a thick bead..just a small smoothed out one so the gasket sticks to the valve cover when i turn it over to stick it on the head..I've never had any leaks doing it this way. I know the 2.9L is a bugger to seal up.
Old Aug 16, 2004 | 08:30 PM
Ken00's Avatar
Ken00
Also make sure the load spreads are in the right places and DON'T over tighten the bolts.
kegger66
22
Jun 30, 2016 11:16 PM
edcantu9
Escape & Escape Hybrid
Jan 22, 2016 10:15 PM
mike L
13
Oct 25, 2015 01:32 AM
lpmorgan
Nov 21, 2005 12:13 AM
gtex
Nov 4, 2003 02:51 PM
