428 Identification
Old Aug 16, 2004 | 12:37 PM
fordification's Avatar
fordification
Question 428 Identification
I know this topic has been beat to death, but I've did a search through the posts and collected all the indicators that I think will help. I just need to know if there all accurate, and if there are any that I've missed.
On my way to the track friday night, I pulled over for gas and a guy came over and started talking to me about the truck. Apparently, he has a F-100 with a 428CJ!! He said he's asking $2000 for the whole truck. Before I make a decision, I want to make certain that it is a 428.
-Head Casting #'s - C8OE-H or N/C8AE-J OR F/C8WE-A
(assuming it's a 68)
-16 exhaust bolts on CJ heads
-"C" welded on back of block for CJ or "A" for 428.
-Remove center frost plug, "428" stamp on cylinder wall.
(not sure which side)
I know the only certain way would be to check the stroke or clearance but I don't think I could get an accurate measurement without tearing the motor apart.
Isn't the 428 externally balanced also? So would there be a large weight on the flywheel (even though some non-428 fw's also have weights). Or how about in the front with the harmonic balancer?
Any info would be appreciated.
Old Aug 16, 2004 | 12:48 PM
rusty70f100's Avatar
rusty70f100
It's a 428. The 428 on the cylinder wall gives it away. The heads could also be 390 heads, but they're probably 428 CJ heads if they're on a 428 block.
Old Aug 16, 2004 | 12:52 PM
fordification
"Some blocks have a "428" cast onto the floor inside the water jacket. There are two common positions to view this protruding number: one is just inside the center freeze plug hole, the other is directly beneath the long coolant slot at the rear of the block."
Anyone know where this is?
Old Aug 16, 2004 | 12:53 PM
fordification
Just to clarify, I haven't looked at the motor yet. I'm just listing the indicators so I can check.
Old Aug 16, 2004 | 02:29 PM
BB's Avatar
BB
Do the stroke test procedure using the #1 and #4 plug holes, you'll be close enough to tell if it's the right stroke.
There's no way of knowing if it's the right bore even with the 428 in the water jackets. I've seen a couple 390's with the 428 cast in. Real confusing!
Only 428SCJ's got the hatchet on the crank spacer.
Not that it helps much but CJ's got the Carter "X" fuel pump. Also, you can see the sandwich of gaskets if it has the windage tray installed.
Stock intake is a C8OE-C
If the stroke and #'s match, I'd go for it anyway. Worst case would be a 410 with CJ parts.
Old Aug 16, 2004 | 03:07 PM
fordification
The guy did mention it had adjustable rockers. Assuming that there factory, what else came with the adjustable rockers? Think the 390 GT did.
Old Aug 16, 2004 | 03:20 PM
BB's Avatar
BB
He probably put them on. They came stock on the '58 FE's, the 352HP, 390HP and PI, 406 and 427 only.
Old Aug 16, 2004 | 05:12 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I Hope its not that kid that trying to sell his 72 f100 with a supposed 428 in it? He live's in Washington state and it not a 428....
Russ
OrangeJuice
Mar 2, 2010 12:47 PM
muscletruck
Apr 12, 2009 02:13 PM
brandon75_390
Apr 28, 2007 09:30 AM
astamp78
Feb 2, 2002 10:02 AM
bigblue
Sep 11, 2000 07:53 AM
