'73 a/c pulleys and brackets
Old Aug 16, 2004 | 09:46 AM
73Custom's Avatar
73Custom
I'm trying to gather the parts I need to install factory a/c on my '73 390. I'm having a terrible time finding the correct pulleys and brackets - I can't even find and '73-76 with FE and a/c... I've managed to find a crank pulley with 3 grooves (all three the same size) but can't find a water pump pulley with 3 grooves the same size (if there is such a thing) - only 2 grooves or 3 with the front one larger diameter, what is correct?
Anyone have pics of a '73-76 FE a/c brackets and belts?
Thanks.
Marty
Old Aug 16, 2004 | 10:46 AM
uemf's Avatar
uemf
my '73 360 with factory air has a 3 groove pulley for the water pump. the ac uses the outer pulley on the 3 groove pulleys.
There are 2 brackets that hold the compressor. one is a very heavyduty (thick) right angle bracket that is bolted to the drivers side head. the bolt on the outside also secures the P/S pump.
the comp. sits on this bracket and is secured with 4 bolts.
there is also a large bracket that has an idler pully on it. one side shares the pivot bolt with the altenator adjuster bracket(curved). this bracket goes above the water pump. and there is another bolt on the drivers side of the engine. the top of the braket bolts to the side of the comp.
I took some picks and will see if I can post.been needing to get a shot of my truck anyway. I haven't been able to find my camera since we moved, borrowed one a couple of days ago.
Old Aug 16, 2004 | 11:00 AM
73Custom's Avatar
73Custom
Thanks for the post, I assumed the w/p had 3 grooves too - my search continues... Any pics of your engine would be a great help, thanks.
Marty
Old Aug 16, 2004 | 11:17 AM
uemf's Avatar
uemf
just posted some
Old Aug 16, 2004 | 01:46 PM
73Custom's Avatar
73Custom
The pics are just what I needed, thanks. Now I just need to find some...
Marty
Old Aug 17, 2004 | 08:31 AM
rakent's Avatar
rakent
I'm looking for the same setup - a/c brackets and pulleys for a '74 360. I appreciate your letting me know if you find a source.
73Custom
Mar 13, 2016 11:07 PM
BadDogKuzz
13
Mar 3, 2016 07:47 PM
abyars111
Oct 8, 2015 12:05 PM
abyars111
Mar 28, 2015 09:45 PM
abyars111
Mar 23, 2015 10:23 AM
