Looking for Injector Harness Ends
Old Aug 14, 2004 | 04:39 PM
Nickiboy's Avatar
Nickiboy
Does anyone know where I may finds the outer plugin electrical fittings for the Injectors and glow plugs ?...... I have a 95 F250 PSD 7.3 ltr. ....... 2 of the 4 plug ends are slightly burned and Im trying to avoid replacing the entire engine harness ($600.00 bucks at Ford dealer) ....... I've already bought the short harnesses under the valve pans but 2 of the outer connectors on the main harness need changing too....... Im hoping someone sells the connector ends with short wires that can be spliced into the main harness and save me some major bucks ......... Any ideas ??
Old Aug 14, 2004 | 05:39 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You might check with Sean at SPdiesel, www.spdiesel.com He seems to be able to get all kinds of oddball Ford connectors that everyone else has problems with.
Old Aug 14, 2004 | 06:01 PM
believer45's Avatar
believer45
Check your other thread - I just posted some information there for you.
Dave / Believer45
Old Aug 14, 2004 | 09:19 PM
International Tech's Avatar
International Tech
Just checking but does it have 1 or 2 connections at each valve cover? I think i have an old harness at the shop and will check on monday. If i have the right one id be glad to give them to ya.
Old Aug 15, 2004 | 10:54 AM
mud rat jr.'s Avatar
mud rat jr.
i went my ford dealer and asked the diesel tech if he had any and he gave them to me
a 12 pack will go a long way.
Old Aug 15, 2004 | 10:58 AM
believer45's Avatar
believer45
It should be two connectors four pins each for each valve cover. The newer trucks went to a single connector on each side.
Dave / Believer45
Old Aug 15, 2004 | 11:07 AM
International Tech
ok ill check on monday (2 connectors for each valve cover.)
Old Aug 15, 2004 | 11:10 AM
believer45's Avatar
believer45
HERE IS A LINK to the other thread.
Dave / Believer45
Old Aug 16, 2004 | 08:12 PM
Nickiboy's Avatar
Nickiboy
Thank you Int. Tech.......... My truck has the 2 connectors on each valve cover and I sure can use them if you can find em.
Old Aug 16, 2004 | 08:29 PM
International Tech
Hey there i checked today and i have the newer style harness. Sorry. I wish i could have helped.
