Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
air compresor regulator
Old Aug 14, 2004 | 08:20 AM
Pilgrim's Avatar
Pilgrim
Bought a new 2-stage 175 psi air compressor. Since most air tools recommend 90psi, does this mean I need to run a regulator on it exept for the times when I specifically need the high pressures?? My old one only went to about 110psi so I didn't use a regulator, just gave it all it had!
Old Aug 14, 2004 | 09:45 AM
Cliford's Avatar
Cliford
Yes you would need a reg. if you get one get a large one for the volume to go thoough it. Or you could lower the cut out PSI to about 125 and use it that way if it was mine that is what I would do. Higher the PSI the lower the CFM
Old Aug 14, 2004 | 09:56 AM
Torque1st's Avatar
Torque1st
Posting Legend
Running the pressure to 175 PSI and then regulating back down wastes a lot of energy.
Old Aug 14, 2004 | 05:12 PM
Sberry27's Avatar
Sberry27
Air isnt extremely effecient anyway, actually not at all. Its to do work. Leave the factory settings where they are and go to HD or Lowes and get a regulator and filter. Get the one with 3/8 ports. Its plenty for that comp. You can mount it direct but I might go to TSC store and get a ready made hydraulic line to go from the comp to the filter, you could mount it remote. Yes they hyd line is overkill but they are ready made with the ends on them and available in a variety of lengths. Makes it real easy. While you are there you could check out hose reels, another nice addition. You will likey need a couple of reducing bushings and a pipe nipple or 2 to do this setup.
Old Aug 16, 2004 | 10:08 PM
1BigFish's Avatar
1BigFish
If you leave the fact. setting of 175 psi,make sure the filter-regulator is rated for at least 175 inlet pressure. In my experience, you won't find em at your local lowes or home depot. Your best bet is an industrial supplier like Graingers.
Old Aug 16, 2004 | 11:10 PM
dono's Avatar
dono
Gone but not forgotten.
I have three on my set-up. One at the compressor, one on the output of the filter and a third at the end of the hose when I am airbrushing.
Dono
Old Sep 8, 2004 | 12:35 AM
460f250's Avatar
460f250
I've done just what Sberry suggested about the flex hose and remote mounting and it seems to work well. I've started to run my lines with galvanized pipe but there are enough leaks in the system between the galvanized and copper that it won't hold pressure. I think it was said here NOT to use thread tape but can't recall why it was so important. If the tape is on the threads well back from where it can get into the air stream what could be the problem?
Old Sep 8, 2004 | 09:25 AM
BenW84's Avatar
BenW84
On my compressor set up I have a ball valve set up to turn the air on and off or half way in between. From the ball valve it goes into a rubber line to absorb shock then into 1/2" black pipe. I then have regulators and water seperators at each outlet. This works well for me.
Old Sep 11, 2004 | 07:21 AM
f350xlt460's Avatar
f350xlt460
thats the set up my dad has, 80 gal 175 psi. He has 175 going to 2 hose reels. He does have an oiler/regulator for air tools, it regulates down to 90 psi and oils.
Old Sep 11, 2004 | 09:41 AM
Torque1st's Avatar
Torque1st
Posting Legend
Always use paste type liquid pipe dope. From my expeience you will have FAR fewer leaks to contend with. I almost never use teflon tape anymore.
There are a number of threads here, some in the archives, that have good information on how to set up a shop air system.
My compressor is set to cycle between 100-115 PSI and works well for all of my needs. I sometimes have to wait a moment for it to build to full pressure for a stubborn bolt but not often.
Check my gallery for a good lubricator to use for air tools. This point of use lubricator keeps my air lines clean.
musicars
Oct 27, 2014 03:48 PM
Richard Olshefski
May 1, 2014 06:55 AM
F250Rob
Garage & Workshop
Jan 31, 2005 06:58 AM
F250Rob
16
Jan 27, 2005 05:33 AM
lmccoury
Garage & Workshop
Sep 8, 2002 05:31 PM
