fuel pump
Old Apr 16, 2001 | 08:48 PM
lowcountry's Avatar
lowcountry
fuel pump
I have a 91 explorer and was working on replacing the blower motor and relay. when I got it all back together all was working fine move the truck around to the front of the house and let it set. came out two hours later and herd the fuel pump running and I cannot figure out why, no key in the ignition checked the max fuse relay under the hood relay is good from what i can tell. I am completly stumped.
any help would be appreciated
Scott
LowCountry Swampers
Old Apr 16, 2001 | 10:06 PM
PAUL_2's Avatar
PAUL_2
fuel pump
The fuel pump relay is stuck open , tap it & the fuel pump should shut off . Replace the fuel pump relay .
Old Apr 17, 2001 | 05:29 AM
lowcountry's Avatar
lowcountry
fuel pump
ok silly ? where is the fuel pump relay located at?
Scott
Old Apr 21, 2001 | 09:31 PM
Db3frdlvr's Avatar
Db3frdlvr
fuel pump
Underneath the power distribution box behind the battery. There are other relays under there as well (Information for future use).
HTH
Dex.
Old Apr 22, 2001 | 11:51 AM
tbejr's Avatar
tbejr
fuel pump
lowcountry
2004 - 2008 F150
Jan 3, 2007 08:37 PM
lowcountry
Nov 23, 2002 05:07 PM
lowcountry
Jul 12, 2001 12:41 PM
lowcountry
13
Jul 11, 2001 09:47 AM
lowcountry
Jan 17, 2001 12:40 PM
