Brake sticking
Old Jan 3, 2007 | 05:14 PM
lowcountry's Avatar
lowcountry
Brake sticking
Hi all,
Dumb ? here, I just changed out the front pads on my 05 f150 4x4 and yesturday it seemed that both calipers where sticking and causing drag today the passenger has starting working fine. The driver side is causing so much heat that i can smell it burn. If the caliper is stuck and i have to bleed the brakes can I just bleed the one or do i have to do all four
Thanks
Scott
Old Jan 3, 2007 | 08:37 PM
ubereal2's Avatar
ubereal2
Red face twisted hose???
I'd have to check a couple easy things first. I've seen disc brakes done, and the person had a twist in the rubber brake hose. This won't let the fluid pressure go and release making the brake stick.
ford8n47
Dec 22, 2019 06:36 PM
texasjack
Mar 15, 2014 07:52 PM
poq-ff-19
Oct 18, 2013 12:28 PM
DiggerF4
Nov 22, 2010 08:53 PM
cornholio337
1983 - 2012 Ranger & B-Series
Oct 16, 2005 06:10 PM
