Anyone know anything about this product? My brother in law just got a 04 6.0 with one installed but has no info on it.
How does it compare to the diablo other than looking more expensive since the site we found it on has "call for price"?
It does make the truck run but it also has a banks exhaust and some guages, dealer has to put new tires on the thing since all the test drives put excessive wear on the rears (17 inch wheels, dont know tire size).
Maybe I can help on the Edge product. I just hooked up mine 5 days ago & can email you the literature that came with it if you can't find it on the www.edgeproducts.com website. I like it along wity my 4" monster exhaust from turbo back & bypassed cat on 2004 f250 psd. Rick
If you do some research on the edge you will find out that it is very under rated. I have the edge with attitude controller and it is crazy! Look at my gallery for my track times. With on the fly HP tuning and the digital read outs it is a great buy.
I would advise a turbo back exhaust due to the high temp produced buy this unit. other wise you/he will be very happy
Bob i need to take my truck to the dyno and see what it does but yours are very good.
IMO the predator is very good and updatable. But the edge(IMO) makes more power. If you plan on running gauges you will spend near the price of the edge if you go with the predator and two/three gauges and the pod. Also I have had the problem of the coolent leak, out of the cap some have said that the timing is to high with the predator and that is the cause. Also the predator has the ability to remove the speed limiter,reset codes and monitor many sensors edge does not. Both have good and bad points and it all come down to a matter of preference! That is why i have both but most people wish not to spend that much money. I am waiting for the latest greatest updated flash for the Predator and then i will let you know more.
He bought a Predator and runs them both! He uses the predator for the transmission shifting and the speed limiter removal.
It's a myth that the Predator makes it blow water. I have 20,000 hard miles without loss of a drop. Most others on this forum will report the same thing.
My HP numbers on my gallery are with a stock exhaust.
PSD I never was able to get the file for just the improved shifting so the only thing loaded was speed limiter removal. Defueling was the same.
For the those who want to get around the speed limiter( at your own risk) you can take out the speed sensor fuse and install a switch in its place. I dont remember what # fuse it is. My truck w/manuals are in the shop. If you are looking at the fuse panel its in the first row going down right side. It will be the second one down 10amp. Hope this helps
