1978 - 1996 Big Bronco
timing problems
Old Aug 14, 2004 | 06:05 PM
beastybronco's Avatar
beastybronco
yes i checked its definatly compression stroke and i used a piece of wire to verify that the piston topped out very close to tdc marking on h bal, also i tried alot of different timings the engine didnt fire on any
i replaced some ignition parts - coil, module, wires, rotor, cap, plugs
checked fuel pressure also
i dont know what could be wrong with it but i know if i dont fix it tonite or tomorrow im gonna hafta put her in the s-h-o-p
Old Aug 14, 2004 | 07:23 PM
Pam's Red's Avatar
Pam's Red
You have my sympathies if you have to take it to "professionals'. The only time I have run into where an engine would not even make firing attempts or noises with starting fluid was when I cranked the rockers down so far the valves could not close. (the shop manual had a misprint, my 1966 Mustang it should have been 1/2 turn not 2 turns to adjust valve lash(yes it was new in 1966))
Pam
Old Aug 24, 2004 | 11:41 AM
RJF3504X4's Avatar
RJF3504X4
In line spout connector
I have a F-350, I just bought it a month a go, were is the in line spout connector located? I'm new to the Ford family. I jumped from GM.
Old Aug 24, 2004 | 06:20 PM
beastybronco
well on mine the connector is right where the icm plugs in
well i took it to the shop and somehow they reset the timing, i have no idea what i could have missed its running alright now
Unrealo4
6.7L Power Stroke Diesel
May 21, 2022 02:18 PM
Fordfanatic69
Jan 9, 2017 06:28 AM
ranagent
Jan 3, 2017 11:23 AM
pounder90
1997 - 2003 F150
Dec 23, 2016 08:25 AM
cefb
21
Sep 3, 2016 09:38 PM
