Pre road trip mod list
I'm looking for feedback on my list, some of this stuff I've done before on the excursion, some not. If I need a specialty tool or extra seals etc. please let me know!
F350 with mods listed in signature, 104k miles
1. Power steering hose, is it the pump to hydroboost hose that bursts?
2. hpop hoses, they're original, should I go ahead and replace? Anything needed besides the removal tool?
3. I haven't been under the valve covers, it runs fine, no hiccups or anything, should I do the .50 mod or replace the harnesses while I'm there? Worthwhile to replace glow plugs while I'm in there? I've done the .50 mod on the ex, but that's all I did there, looked overwhelming to me at the time under there so I closed it back up before I forgot where all the bolts went!
4. Turbo stuff.... I've got the ats housing, I just bought a set of up pipes, I've done them before on the ex, not looking forward to it... Thinking about getting a billet wheel and putting the stock housing back on while I've got the turbo off, might be able to sell the ats housing to recoup cost of the wheel? Also going to gut the pedestal while I'm that deep. I've got a turbo re install kit and everything needed for gutting the pedestal.
Anything else that's simple to do while I'm doing this stuff? Thoughts on what I'm doing?
The PS hose is between the pump and the brake booster - it is the only one with pressure. HPOP hoses are quick and easy with the removal tool. UVCH.... It's always a good idea to at least inspect how that's doing after all these years - but given the failure rate of the UVCH, a new set is cheap insurance. GPs? Naw. You don't have enough miles to warrant that.
That turbo mod needs time to troubleshoot and correct before the trip if things go sideways. Will you have that? When was the last time your transmission was maintained? The fuel bowl likely has tired seals, unless you replaced those when you addressed the heater. What is the condition of your spare and its hardware? When was the last time you greased your brake caliper slide pins?
You might surmise my theme here - I would make sure it's 100% before looking at going to the next level. At the very least, conducting these "chores" will familiarize you more with your truck - giving you a higher degree of confidence and comfort if things do happen on a trip.
Yes the transmission had a full flush 35k miles ago when I installed the 6.0 cooler. Planning on a dump and fill but I didn't mention it.
Last summer when the fuel bowl heater shorted I unplugged it, taped it up, and haven't done anything since. I did rebuild the fuel bowl about 2 years ago so all the seals are in fine shape. Spare is a recent take off with some decent tread left and not horribly old. Replaced rear calipers last summer, definitely a great idea to grease up the fronts.
Perhaps an oil/filter change and a fuel filter change? If near their time, I would do it early enough to have several days of driving BEFORE the trip just to make sure there are no post-change leakers.
