94 Explorer Shudder
Old Feb 5, 2001 | 10:28 PM
brt's Avatar
brt
94 Explorer Shudder
I have a '94 XLT that has a vibration that occurs at low speeds (from a stop). It is felt from the middle of the vehicle. It feels like the transfer case is engaged (but the t-case is in 2WD with hubs unlocked. Ive had it up on a rack and the u-joints are OK, wheel bearings are OK and nothing is out of place. It has 75,000 miles. Has anyone had this experience? Thanks for any info.
Old Feb 6, 2001 | 12:45 AM
PAUL_2's Avatar
PAUL_2
94 Explorer Shudder
Does it have aluminum rims ? Is it possible one of the rims may be damaged ? How many miles on the tires ? It sounds like either a tire or rim problem .
Old Jun 6, 2001 | 11:10 AM
reberhardt's Avatar
reberhardt
94 Explorer Shudder
Old Jul 26, 2001 | 10:18 PM
hammer58's Avatar
hammer58
94 Explorer Shudder
Does this occur only on a turn from a stop? If it does, it could be the limited slip rings in the differential. Usually an addative in the rear end will stop the noise.
Old Jul 31, 2001 | 03:07 AM
douglapd's Avatar
douglapd
94 Explorer Shudder
Check the output flange nut on the transfer case. Remove the front driveshaft bolts and check that the flange nut is tight, mine came loose @ approx. 75,000 miles.
f350custom
16
Jan 5, 2016 02:57 PM
Redneckfordf2502002
15
Jan 31, 2014 12:40 PM
goda123
Nov 30, 2008 04:37 PM
mad scientist:p
Jun 7, 2006 02:16 AM
Mike in RI
Jan 2, 2004 07:38 PM
