Trailer socket questions.
Old Jul 24, 2001 | 09:41 AM
scifi30's Avatar
scifi30
I have a '94 Explorer with a trailer pkg. I'm tring to find the running light terminal in the 7 pole socket. I can find the 'common' and the 'battery recharge hot', but when I do a circuit test with my head lights on I don't get a hot circuit on any of the terminals except for the one I already had ( the battery recharge).
Doesn't anyone have any idea what might be happening. I have a good clean ground. I'm wondering if it is a Ford thing related to the relays in the rear tool compartment.
TIA
Steve
Old Aug 5, 2001 | 09:35 PM
Dialtone's Avatar
Dialtone
According to my wiring diagram, there are 3 relays associated with the trailer package. One each for left/right stop&signal lamps, and 1 for tail lights. Left stop comes out on a Yellow wire, right stop comes out on a Dark Green wire and tail light come out on a Tan/White wire.
The tail lamp relay has battery from the head lamp switch on one side of the operate coil on a Brown wire, ground on the other side of coil is Orange. Battery for the tail lamps is fed from an instrument fuse panel to the relay on a Yellow wire thru the contacts and out on a Tan/White wire to the plug.
Hope this helps
Dialtone
Old Aug 6, 2001 | 07:54 AM
campduck2000's Avatar
campduck2000
kr98664
'80-'86 HOWTO's
25
May 11, 2025 12:03 PM
Etzcutter
Jan 2, 2017 08:18 AM
ejanzen
Jan 1, 2014 05:41 PM
Coccyx
Jul 10, 2010 12:45 PM
Mark 42
All Things Towing
Mar 8, 2004 10:35 AM
