how do i mount the body
Old Aug 9, 2004 | 04:23 AM
bootie's Avatar
bootie
i need some info on mounting the body - due to the fact my truck came in kitset form i keep getting lost as to how things fit together so if anybodys got some diagrams or anything to show me how to put it back together please halp
Old Aug 9, 2004 | 11:21 PM
alittle40's Avatar
alittle40
Show me a picture of what you got and I'll see if I can help you out. My truck came in 250 boxes and no manual supplied by Henry Ford.
Old Aug 9, 2004 | 11:46 PM
bootie's Avatar
bootie
opps i've got a 47 ford pickup no pictures that i can post as yet - don't own a dig camera or a scanner but get 1 soon
Old Aug 10, 2004 | 11:53 AM
alittle40's Avatar
alittle40
Lay out your parts on the ground. Left side parts on left, right on right. If they're greasy they go in the engine bay or underneath, if they're painted they go on the outside, the shiny ones are usually at the bottom and the dull patina ones at the top. After you got it all layout, then partially fit the parts together and then put in boxes in groups. Cab is the biggest part, sit it on the frame and use a drift pin to find bolt holes in the floor and frame, usually take 3 1/2 " X 3/8 carriage bolts. Do a loose fit of cab and frame. Mount fenders to cab and search for frame holes. If you are hitting holes in frame with each new part you put on, then you are on the right track. After you have the basic truck assembled, take it apart, number connect points and remember how they fit. Take pictures as you go along. When you get back down to just the cab and frame you can start to tweak and adjust with rubber mounts, washers,wedges,and wood shims.
You don't need a dig camera or scanner, just buy a throw-a -way camera and take the pictures and have them put on cd and then you can load up the computer. Take pictures and study pictures of similar trucks and components to see how they are mounted. Don't got go modifying thing that you don't understand just because you got them, things like that usually end up looking like something that crawled out of an alley-cat's *** and they are unsafe too!
Good luck on your endeavours. AL
Old Aug 10, 2004 | 03:33 PM
bootie's Avatar
bootie
its the rubber mounts/wood shims and wedges for the cab i really need to know about
Old Aug 10, 2004 | 11:04 PM
alittle40's Avatar
alittle40
Buy some 1 1/2" o.d. rubber with a 1/2" i.d. hole. slice it up in 3/4" thickness and use it for body mounts to mount your cab and prevent squeaks. Run you 3/8 mounting bolts thru the middle. The extra 1/8 inch will give you a little wiggle room. If you find that you need more of a rake to the cab, raise up the back by using washers to the desired height, then use a piece of hardwood to take up the void, span at least two mounting holes so it remains stationary. Cut a couple of rubber washers a 1/4 " thick and use them between your body and the hardwood filler mount that you made. Check out my gallery on my '40 to see how the cab is mounted to the frame. C U AL
Old Aug 11, 2004 | 10:09 PM
The Frenchtown Flyer's Avatar
Mac's (800-777-0948) makes a six piece hardwood body mount kit for about $80. These pieces are rather complicated - the surfaces follow the contours and metal flanges of the underside of the cab. Worth it. Also try Bob Drake (800-2213673) and Gaslight (?).
Old Aug 12, 2004 | 03:51 PM
bootie's Avatar
bootie
don't have any pics or dimensions for the hardwood mount kit (can always sweet talk my partners dad into making me wood stuff)
Old Jan 5, 2008 | 03:04 PM
whateg01's Avatar
whateg01
Sorry to revive such an old thread, but it's useful!
This question is for alittle40, or anybody else who recognizes the photo. I am guessing from the description and other pics in the gallery, that this is pic of the rear cab mount. But from which direction? And what are some other reference points under here that I can relate to? The floor of the cab that I have has been butchered by a previous owner, and I don't have the original frame, so I'm building a new frame. I'm not going after an original look at all, so in reality, I could do whatever I want for mounting, but I'd at least like to know where the original mounts were and such. Thanks!
Dave
Old Feb 4, 2008 | 12:58 AM
bootie's Avatar
bootie
sorry for the slow reply i sold my truck a year or so ago and am back working on my model A from what i recall the mount in your pic is the front mount as mine just had blocks at the rear i think the taper went to the rear of the truck hope that helps
Old Feb 4, 2008 | 09:53 AM
COMPLIT1107's Avatar
COMPLIT1107
47 Cab Mounts
I have pictures of the cab mounts and locations at http://www.computerliterates.com/47Ford
Click on cab mounts on left side. I hope these are some help.
John
Old Feb 4, 2008 | 03:12 PM
COMPLIT1107
Cab Mounts
After looking at the picture several more times, my guess is that the picture is taken from the front looking down the passenger side. The panel above the frame to the left is the cab panel (door frame) running under the door. The channel piece appears to be cut off which should run across the cab. It appears the lower rear cab corner is missing and we are seeing the bed side extending to the rear. (I did this with my glasses on and off !)
John
Tomahawk2506
Sep 4, 2013 05:29 PM
dieseldodgeguy
Jul 28, 2013 10:37 AM
tom1979
Feb 8, 2007 06:31 PM
ajstephan
Nov 21, 2005 07:25 AM
mic
Jan 8, 2002 12:52 AM
