Gauge Needles
Old Aug 9, 2004 | 04:15 AM
live for the rush's Avatar
live for the rush
Question Gauge Needles
what up i have a 2000 ford Ranger 2.5L I4, 2wd
i recently took out my dashboard cluster to install white gauge panels, and i took off the needles on the fuel ,oil, speedometer, temperature, and battery to put the white panels on ... on the needles, nothing broke off .. so i put them back on , everything was correct. and there were only 3 plugs in the back of the cluster and they all plugged back in right into their spots. now when i turn on the truck or am driving, all the needles dont read right. the fuel reads wrong, the oil is way over the high limit. the speedometer jumps around at wrong speeds, the temp is over high, and battery same.... i didnt mess with any other wires , only the 3 i unplugged and they fit back in fine... can anyone help and tell me what went wrong and what i might have to do to make them work correctly ! Thanks garrett
Old Aug 9, 2004 | 06:01 PM
Jeb911's Avatar
Jeb911
You might want to take the Panel back off. There is usually springs in the speedometer and the other gauges. Once you pull them off, the needles recoil. You might want to check them again
93nighthawk
Aerostar
39
Sep 23, 2015 08:55 PM
Anthony Nicastro
Jan 21, 2013 12:42 PM
Gordon Grooms
Electrical Systems/Wiring
Dec 4, 2012 05:40 PM
I-6 Power
Nov 28, 2012 07:51 AM
nolan62
45
Jul 6, 2011 03:55 PM
