E350 No Turn signals
Old Aug 8, 2004 | 12:15 AM
spike63's Avatar
spike63
Angry E350 No Turn signals
My E350 all of a sudden has no turn signals. I have running & brake lights. I replaced the turn signal relay but no dice any hints?????
Old Aug 8, 2004 | 08:53 AM
HomerWinzlow's Avatar
HomerWinzlow
Look and see if the flasher switch is in the on position. Ive seen many bad multifunction switches with bad 4 way flasher switches. A person accidently pops the switch up in the on position and suddenly they have no turn signals...because the 4 way flasher switch is in the on position and locks out the turn signals. Often popping the switch back down to the off position will restore turn signals. The fix then would be to replace the multi function switch. This of course relies on it being at least a mid 1990s model which you did not specify.
Old Aug 8, 2004 | 10:21 AM
Dealford's Avatar
Dealford
Welcome to FTE!
And of course you did check the fuse.
AL.
whaase
Jun 16, 2015 09:32 PM
johnr9q
Electrical Systems/Wiring
May 21, 2015 11:20 AM
enil01
Jan 4, 2015 06:12 PM
E30tdf
May 17, 2014 12:55 AM
irish70
Dec 8, 2011 06:33 AM
