2000 Explorer 4X4 problem
Old Aug 30, 2001 | 09:45 PM
mholota's Avatar
mholota
The 4X4 HI and 4X4 LO indicator lights flash simultaneously but intermittently on the dash. In making tight turns, it seems the 4X4 is trying to engage. Anyone had any experience with this problem?
Old Aug 31, 2001 | 07:45 AM
SplashMan's Avatar
SplashMan
If you have the "AUTO" 4x4 like my '99, try disconnecting your battery for an hour or so and then reconnect it. That will reset all the little sensors and the ECU unit. You have to drive around at verying speeds for about 20min to help the ECU relearn its settings. Hope that helps.
'99 Explorer XLT SOHc
Old Sep 1, 2001 | 02:45 PM
reberhardt's Avatar
reberhardt
If the lights come back on after Splashman's suggestion, you probably have a faulty speed sensor in the transfercase. It is failing, which is causing the system to think your tires are slipping. Therfore it is putting you into 4x4. Is it still under warranty? If so, let Ford deal with it if the lights come back on after resetting the computer.
Old Sep 2, 2001 | 09:32 PM
mholota's Avatar
mholota
Thank you guys for replying to my plea for help. Yup, it was a faulty sensor on the transfer case.
Old Sep 3, 2001 | 11:15 AM
PAUL_2's Avatar
PAUL_2
outdoormaniac
Mar 29, 2015 09:22 AM
katruck
Oct 31, 2014 08:26 AM
jsp_8701
Jul 1, 2014 06:12 PM
klocker97
Jun 5, 2014 07:34 PM
4x4x4x4
Modular V10 (6.8l)
May 3, 2002 07:38 AM
