Sponsored by: Real Truck
4x4 problems
Old Oct 30, 2014 | 04:48 PM
katruck's Avatar
katruck
4x4 problems
2002 F250 SD 4x4 crew cab, v10. 4x4 not working. Replaced switch on dash, not the problem. Some of told me it was the vacuum control module. Not sure where to start. Any suggestions would be helpful.
Old Oct 30, 2014 | 06:41 PM
da X-man's Avatar
da X-man
What else can you tell us about your problem? Is the transfer case engaging? The vacuum only controls the front hubs (if it still works). If you replaced the switch on the dash, I assume you are having problems getting the transfer case to engage. Check the relays under the hood (there are two by master cylinder for 4wd). Also, do a quick search and see if others had similar issues to you.
Old Oct 31, 2014 | 05:56 AM
redford's Avatar
redford
FTE Leadership Emeritus
When you turn the ****, do you get a 4x4 indicator on your dash display?
What symptoms are you experiencing that indicate 4 wheel drive is not working?
How is your heating/AC system working for you? Can you switch from floor vents to dash vents to defrosters while driving down the road?
Old Oct 31, 2014 | 08:25 AM
katruck's Avatar
katruck
I have no indicator on dash when turning the switch. Heat works fine, can switch to all while driving
Old Oct 31, 2014 | 08:26 AM
katruck's Avatar
katruck
there is no engagement. I will check the relays. thx
sawzall5150
Oct 24, 2015 06:25 PM
Zip
Nov 19, 2014 10:50 AM
clintbonnie
13
Oct 3, 2014 02:56 PM
rama331
Mar 24, 2008 09:36 AM
A.FRY
Jan 17, 2007 09:47 PM
