Distributor almost there, I think.
Old Aug 7, 2004 | 06:08 PM
eandaauto's Avatar
eandaauto
Ok I've gotten to the point where about everything in my ignition is new...plugs, dist cap, rotor, pertronix ignitor, distributor, coil. at tdc on compression stroke, rotor facing #1 plug wire on cap. Still won't fire. Doesn't have the same popping through the carb problem as before, only a little. Any other minor instructions for getting the engine fired? Should I keep the vac advance connected?
Old Aug 7, 2004 | 06:34 PM
eandaauto's Avatar
eandaauto
Hmmm nevermind just redid everything again and it fired right up. I suppose I could have been confusing the exhaust stroke with the compression stroke the whole time before, but I'm not sure. Anyways, thanks for all your help.
Old Aug 7, 2004 | 06:55 PM
fordeverpower's Avatar
fordeverpower
nope everytime it points to number one on the dizzy its the comp stroke. Like i said earlier you need to advance the dizzy 1 tooth when installed. Then when its tightened down it retards back a tooth and is right on. Otherwise you will be a tooth retarded and will have popping and such. Good luck!
Old Aug 7, 2004 | 07:42 PM
eandaauto's Avatar
eandaauto
Thanks, I got it fired up and running now....but I'm havin a little getting the timing all figured out. Engine is stock besides edelbrock streetmaster and carter afb 600, pertronix ignitor. What should I set the timing at? Don't need to adjust the idle at all do I?? Didn't change it from what it was before..
Old Aug 8, 2004 | 02:42 AM
fordeverpower
timing some around 10 to 14 btdc. Now if if idle is quite a bit higher than before you are a tooth advanced and if the idle is lower you are retarded.
Old Aug 8, 2004 | 02:57 AM
ford390gashog's Avatar
ford390gashog
could you further explain the 1 tooth thing i have never heard of it and how do you know when it is up a tooth
Old Aug 8, 2004 | 03:45 AM
eandaauto's Avatar
eandaauto
Thanks ill set the timing somewhere in that range. By a tooth off, you mean the rotor was not facing the #1 wire at tdc?
WillInTheWoods84
Jul 27, 2014 04:25 PM
merlynr
Electrical Systems/Wiring
Oct 27, 2012 09:24 AM
fordster91
1983 - 2012 Ranger & B-Series
19
Mar 11, 2012 03:46 PM
idaho211
15
Feb 22, 2009 06:29 PM
JOSEPHU
Apr 2, 2008 03:35 PM
